I installed a Digitrax DH165AO decoder and added a Digitrax SFX004 (Soundbug) decoder into a locomotive with the address of 65. The sound dosn’t work unless I use the adress 03. I know that I have to program the sound decoder to use address 65. How will I synchronize or program both of them to use address 65?
Depends on your DCC system. Just treat the 2 decoders as a single one and you are good to go. Program it the same way you did your 165.
David B
Did you program the 165 address before you installed the SoundBug? If so, you’ll need to repeat the programming process. The SoundBug works together with the 165-series decoders, but it does have its own address.
The only ‘shared’ CVs are the ones you’d want to program both the same anyway - address, momentum. The ones that control the sounds are all well above the range used by the motor control and function settings on the 165. But you do definitely have to program the address again after you attach the Soundbug, otherwsie the 165 will be using the programmed address and the Soundbug will still be on 3.
It has been a few days since the OP asked for help. Did the help given resolve the situation? If so, could he please let us know rather than leave this thread open-ended, please? It is in bad taste to ask for help and then not offer thanks or let us know what has helped. This is important for people searching these forums.
David B
