Soundbox - Sound for the Un-Soundable
I have a web article about making a soundbox at:
http://www.pacificcoastairlinerr.com/1879/soundbox/
Harold
Harold
Thanks for the reposting of your early pages, and the under-the-table sound article. I had missed the old article on lowering Mantua boxcars - I may use some of the info on some Mantua Old Time gondolas I found on the junk table.
I planned on under-the-table sound in any case for my tiny HO/HOn3 steamers, so reading somebody else’s experiments is very beneficial.
Fred W
Would this system work with two identical sound decoders, one in the engine for direction and one driving an under layout sub-woofer?
I know there are guys with well developed acoustic skills in here who should be able to answer this.
Sure would. If you tuned them the same they should stay in sync. You’d want to add a low pass filter to the undertable one so only the lows go to the sub, or you could use the equalizer if using a Tsunami. In Harold’s example the capacitor is blocking the lows - this capacitor was included witht he old Soundtraxx LC and DSD decoders so that the rumbly lows would not distort the small speakers. For driving a large full-range speaker I’d elmininate that because the speaker being used would be able to reproduce the sounds properly.
Perhaps you all might be interested in my stationary sound decoder project finished in the spring of 2008 and posted then.
http://cs.trains.com/TRCCS/forums/p/129436/1459187.aspx#1459187
I used six sound decoders of various types, a control box with LED indicators, and dual control circuits for programming the decoders and playing the decoders mu’d with various locos.
I use two amplifiers…one dedicated to subwoofers, two sets of speakers and an equalizer.
This is all shown in the photos.
I could find no previous plans so I had to make up the circuits as I went along.
Sounds great…thundering really.
Would you need a resistor across the motor leads of the soun decoder under the table? I blew a decoder, bench testing it with just power to it and no load on the motor leads.
