Does anyone know how to wire a Soundtraxx DSD-LL110LC? I got one without an instruction sheet. It has the 8 pin NMRA connector on it but I can’t tell which pins the speaker should be connected to. Googled until my fingers started to bleed but couldn’t find the info.
Read those instructions… The 2 purple wires are the speaker wires and one of them must have a capacitor connected between the wire and the speaker terminal. The speaker doesn’t go through the plug, that’s only for basic lights and the motor functions. Make sure you get that speaker wiring correct, damage could result if you don’t.
Ah, so, that’s the trick. They don’t use the plug at all. I thought that might be the case but didn’t see any obvious place to do the soldering. If you could send that instruction sheet that would be great. Thanks a bunch.
For others info, the manual on Soundtraxx website does not pertain to the plug’n’play decoder for Lifelike. I’m missing the instruction sheet which must be packaged with the decoder, but which is not posted on the website.
