Soundtraxx kt1000
Has anyone installed a Soundtraxx kt1000 into a Kato SD70, thinking about it but have my fears in doing do. Canott figure out where the speaker would go… Any help greatly appreciated. Thank you…
The below link “might” help. There are three Kato’s in there, just not yours. The frames “might” be similar.
Store the link in Favorites. Look at all his pages as he has a lot of good DCC info. Bruce use to own Litchfield Station.
http://www.mrdccu.com/install/hods/index.htm
Check the fuel tank. Late run Kato’s have a place for a speaker in the fuel tank.
I could not find any photos on Kato’s web page to check.
Ok, did some more Google searches and found the below. Not a Tsunami but this will give you an idea.
http://www.ulrichmodels.com/prostores/SoundUpgrades/Kato_C44-9W_Revolution_Install.pdf
The page says and other Kato.
Everyone, store the link in Favorites. You might need it in the future.
Do NOT put the speaker in the fuel tank…BAD, BAD idea.
There is plenty of room in the rear of the long hood for a speaker/baffle. You will need to cut the light tube back for the rear light (as well as the tube mounts) and mount your LED to the back of your baffle.
David B
Thanks for you response, but I have no idea what you mean. Cut the light tube and mount LED to the baffle? Sounds very foreign. Thanks…
