Soundtraxx Tsunami Question
I have a Soundtraxx Tsunami GN1000 installed in an Athearn RTR Dash 9 unit. I am using NCE PowerCab.
When I finish changing CVs in Program mode, the unit will sit still and the lights will flash. After a while it will be fine and work okay. Is this normal?
Yes, this is completely normal. That is the loco telling you that it is receiving the changes in CVs.
Please note that if the loco is moving and you use OPs mode, nothing will be apparent. Flashing lights only occur is the loco is idle.
David B
Thank you David,
This is the first time I have dealt with a Soundtraxx decoder. So far I am liking it.
You will continue to like it I’m sure. make sure you visit the soundtraxx web site and download the user manual and program manual. Both are quiet large but they will show you the flexibility you have with them.
Good Luck.
