I recently installed a Tsunami TSU-750 decoder in a P2K SD60M. Everything functions as it should, however the headlight and reverse light are illuminated at the same time during track power, even if F0 is not on.
What confuses me is that I did not have this issue when the install was originally done; it only started a few days after running the locomotive. I’ve checked the wiring and everything is wired as it should be. I’ve tried a decoder reset and nothing. Wondering if anyone has any insight as to what my problem may be.
Thanks!!
