I am new to the hobby and have decided to model upstate New York in the late 19th century to about 1920. The roads of particular interest are the Northern Central Railway and the New York Central & Hudson River Railroad. Both served Canandaigua, NY and Ontario County, NY in that period. Quickly I found out that finding locomotives and particularly rolling stock for those eras is at best, challenging. Searching the web, I noticed that every few years someone asks a similar question - “are there any sources for 19th century locomotives and rolling stock”. A handful of replies pop up, but it seems that a number of those sources are no longer in business. So, here is the 2023 edition of the question - are there any sources for 19th and early 20th century locomotives and rolling stock? My apologies if anyone has recently asked this question and I didn’t see it. Thank you.
MAikey,
You didn’t indicate but are you modeling in HO? If not, ignore the rest of my reply…
Locomotives → USRA 0-6-0s, 0-8-0, and 2-8-2 Mikes would address the latter end of your chosen era and 2-8-0s & 4-4-0s the earlier-to-mid areas. Here’s a quick list of those how produce them
- 0-6-0 - Proto 2000 (Life-Like or Walthers)
- 0-8-0 - Proto 2000 (Life-Like or Walthers)
- 2-8-2 - BLI & Bachmann
- 2-8-0 - BLI & Bachmann
- 4-4-0 - Bachmann
You can also find most of the above, as well as unique locomotives in used brass for decent prices. Brasstrains.com is a very good & reputable vendor but their prices can be steeper than picking up brass from places like eBay. My handful of NYC brass locomotives - steam & diesel - has primariliy come from eBay and most have been very smooth runners.
Rolling stock → Accurail 36’ double-sheath wood boxcars (i.e. 1300, 1400, 1700 & 1800 Series) - These are kits rather than RTR but they are relatively simple kits to put together and quite handsome when completed. Be sure to click on each series to see the list of roadnames offered. Accurail also lists the original BLT/NEW date and any repainted date for each of their offerings.
HTH,
Gidday, [#welcome] to the Forum.
Forum member Dave Husmans layout timeframe is 1900 to 1905. His website is a goldmine of information, and well worth a read even for the likes of myself who is inclined to the 1950s.
Cheers, the Bear.[:)]
Athearn Roundhouse has some old time models. You can filter by era on right side of screen:
In addition to the Accurail line, MDC/Roundhouse produced a broad line of 36’ truss rod box boxcars and reefers; also long and short passenger cars - all easy to assemble once you do some filing to clean up the cast metal chassis. Craftsman kits from LaBelle, Ambroid and Huff-n-Puff require more work as you’re starting from “a box of sticks”.
Local model train shows/swap meets are great places to acquire lots of these kits for very little money.
Jim
Locos like these Bachmann 4-6-0s would be a good choice for a late 1800s or early 1900s layout…
(Click on the pictures for an enlarged image)
…but since my layout is set in the late '30s, I opted to modernise them, using some older (but more modern-looking) cast-metal boilers, then re-working the old-time slide-valve cylinders into more modern piston-type ones, and adding more modern cabs (leftovers from some Bachmann 2-8-0s)
Here’s one just prior to heading into my paint shop…
…and two of them in-service…
Late 19th century to early 20th century is quite an era range if 1920 is “early.” That would mean 1880 is “late.” 20 years is 1 pretty good chuck of century! And as it happens railroading was undergoing major changes in the decade before and after 1900 , from airbrakes and eletric lighting and steel underframes and so on. And as Wayne points out, even the “same” locomotive built in 1890 or 1895 would have looked different by the end of its useful life in 1925 or so, from valve gear to stack to headlight, cab, tender, and so on. Still it is useful to think in terms of railroad rolling stock having a useful life in the 30 to 40 year range.
So thinking of circa 1900 in general it seems like slim pickings out of the modern catalogs, although Bachmann has some things or did in recent years, but not bad if you include used and train show and swap meet fodder. The Mantua General 4-4-0, AHM 4-4-0 Reno, the Bachmann 4-4-0s which I think were intended as Golden Spike locomotives of 1869, the little PRR A3 class 0-4-0 that AHM had in its catalog, are examples of locomotives that would have been in the last gasp of their active careers in the earliest years of your time frame. By then stacks would have been straight and likely the wood cabs replaced by metal; air brake pumps added, and the long old fashioned cow catcher pilots replaced by something shorter that could handle the modern coupler rather than the long steel bar for the link and pin on the pilot. If you have seen photos of the how Civil War era “Texas” has been restored and preserved that is the look you want. No more gaudy coors, Straight stack, simple pilot.
And that brings up the fact that some of the lines of detail parts that would be so useful for those kinds of conversions have become harder to find too,
The Tyco/Mantua 4-6-0 and 2-6-2 would also seem like good choices. Pemco, a brand long gone that IHC partl
Locomotives: Used brass.
Rolling stock: Westerfield and Funaro & Camerlengo.
-Kevin
I think most of the stuff available for ‘19th Century’ is either older or Western in appearance. One starting point might be the ‘large-drivered’ Mantua camelback 4-4-2; I think the Bowser NYC 4-6-2 is a good representation of what Cole was designing before WWI, some of the prettiest and best-proportioned engines built. Of course most anything USRA is ‘pre-1920’ – and that might include predating a N&W Y class…
There’s an active modeling community for Civil War railroads, but I don’t remember a counterpart for late-'80s and '90s locomotives.
That doesn’t mean you can’t buy the products, you just can’t buy them direct from the company. You’ll find a lot of products are easily found at model railroad flea markets or shows, even if they haven’t been in production in this century. Plus, some companies that used to make kits (decorated or undecorated) now only make the item as ‘ready to run’ - so maybe you can buy a RTR passenger car for $40, or an old kit of the same car for $10 at a train show.
Anyway, I second the thought of the very nice Mantua 4-4-2, and the old MDC/Roundhouse “Pullman Palace” cars are very nice - plus you guy search around on e-bay and find one-piece plastic / resin interiors for them now at a reasonable price.
Trix made a nice plastic NYC wood caboose a few years back, you may be able to track one down…they’re made in Germany, I got mine from the website of a hobbyshop that carried a lot of German-made trains.
Presently eBay sellers are asking 2X MSRP for that particular caboose. [xx(] And there are a few fixes needed, if you lean towards wanting a correct NYC 19000-series caboose. Otherwise, it’s fine as is…
One thing that you have to realize is that late Victorian (“Gilded Age”) and Edwardian US Railroading is a pretty esoteric subject, so their aren’t many people modeling that period, so the manufacturers don’t pay much attention to the period.
First, in any case such as this, join the historical society for the road you are interested in
NYC =NYCSHS | NYCSHS Website – New York Central System Historical Society
Northern Central (The Chemung RR, Elmira, Jefferson & Canandaigua RR, and Sodus Bay & Southern Ry. were consolidated on December 31, 1886, to form the Elmira and Lake Ontario Railroad Company, a continuous line from the Erie interchange at Horseheads to Sodus Point, with a branch from Stanley to Canandaigua. It was leased and operated by the Northern Central, which reached it via the Elmira and Williamsport Railroad, another subsidiary, and trackage rights over the Erie from Elmira to Horseheads. The lease was transferred to the PRR, which controlled the Northern Central, on January 1, 1911.) - Home - Pennsylvania Railroad Technical & Historical Society (prrths.org)
As a SPF (Sloberin’ Pennsy Freak), i can state the following have incredibl
Hi there. For civil war era engines, a number of manufacturers made nice looking engines in HO scale over the last 40 years. But beware: many do not run well, especially the plastic 4-4-0 engines with the motor in the tender. Bachmann recently released some 4-4-0s Civil war era engines, with new tooling, with the motor under the boiler, DCC sound. I have one and they run very nicely. Do not confuse them with the older Bachmanns that had the motor in the tender arrangement.
For 1900’s era engines, Bachmann also sells a nice modern American 4-4-0s and 2-8-0s (motors under the boiler). I have some that run flawlessly. Athearn also offers a 1900’s 4-4-0 and 2-6-0. I have a 4-4-0 model, and it runs great. It’s a little bigger than the Bachmann model. Athearn also sells a nice oldtime 2-8-0 (I also have one of these, runs great).
Passenger and other cars are widely available, old and new. Bachmann sells a range. Old Rivarossi, Pocher, Model Power and MDC cars will run well if you change the wheel sets.
Simon
Thanks Tom. Yes, I am modeling HO scale. Your information is very helpful.
Bear, thank you for the link. Very interesting.
Dave,
Thank you for the information. Lots to digest. As I think through what I want to do with the layout, I am beginning to narrow my timeline. At this point about 1900 into the 1920’s will be my target. I seem to be at the bottom of a steep learning curve when it comes to the evolution of individual locomotive models. Fortunately, folks like you make that curve more managable.
Very nice locomotives Wayne. Modifying locomotives at this point is, unfortunately, above my skill level.
Thank you all for your replies. They are interesting and informative. As a point of information (which I neglected to mention in my original post), I am modeling HO scale. Also, I have decided to narrow my timeframe to around 1900 into the 1920’s. By using a number of your suggestions I am begining to unearth period correct rolling stock. My biggest challenge is finding images showing how Northern Central locomotives and rolling stock are marked. Gunnarsson’s book, Story of the Northern Central Railway, is of some help, but images showing NCR marked rolling are few. But, the adventure continues.
Are you sure they weren’t lettered for the Pennsylvania RR? Often when a large railroad took over a smaller one, like PRR took over the NC in 1861, the small railroad might continue as a “paper railroad” but all the equipment, advertising, printed schedules, etc. would carry the name of the large railroad/owner. Perhaps some equipment might have small initials somewhere indicating the prior railroad (like Soo Line GPs that had a small “WC” to indicate they were part of the old Wisconsin Central.)
Generally, the farther back you go and the smaller the railroad you model, the harder it gets to find suitable models. Modelling the NYC and PRR after WW1 would be relatively easy, as many cars, steam engines, structures, etc. are readily available RTR or as kits.
One option might be to free-lance a “what if?” railroad…like ‘what if the Northern Central had remained an independent railroad?’ Then you can use your research to create credible versions of the railroad’s equipment, using what’s available for the era you wish to model.
