According to FAA’s Air Traffic Control by the Numbers 2019, the average number of go arounds at Newark International from 2014 through 2018 was 2/10s of 1 percent, which was the same as 13 of the 30 core (largest by operations) airports in the U.S., e.g. DFW, IAH, LAS, LAX, etc. San Diego had the highest percentage of go arounds at .6 percent, followed by LGA and DCA at .5 percent. JFK was .4 percent.
“Go-Arounds occur when an aircraft is on approach to the runway but suddenly aborts the landing. This occurs if there is a sudden shift in the wind, an obstruction on the runway, or possibly, the aircraft inadvertently overshooting the runway. Go-arounds result in the aircraft returning to the landing queue to attempt another landing.”
Newark was Number 5 with respect to diversions, which occur when a flight is routed to a different airport than its original destination. This occurs usually due to convective weather. Newark had an annual average of 655 diversions from 2014 through 2018 compared to 1,274 at ORD, 1,508 at DFW, 1,066 at ATL, and 991 at DEN.
Newark is a busy airport. But not as busy as ORD, ATL, and LAX, which averaged more than 700,000 controlled flights per year from 2014 through 2018. Newark was 11th with an average of 427,414.
Newark topped the list of delays. It had an average of 30,176 delays per year from 2014 through 2018. The next highest delays were recorded at LGA, SFO, ORD, and JFK. Weather was the major culprit in these delays. EWR, LGA, SFO, and ORD accounted for half of all the delays of the core 30 from 2014 through 2
