will this engine run on ana[?]log track?
[#welcome] trainman4 to the forum !! That sounds like a pretty big engine you have there, congratulations !! Are you calling the traditional Lionel track, analog track ? I haven’t heard that term for track before, so be sure & tell us what you have in track. Also I believe your engine will run on it, it’s just the radius to be concerned with. You may need at least 42 inch diameter curves for it to negotiate. We’re not sure exactly which eng. you have either, as they have made a few over the years.
Thanks & let us know what you have !
It’s N scale running on kato unitrack.I had it running on this track with the dcc hookup but i want to try it with out the atlas master hook up.Thank you very much for your quick reply
the engine is a key sp cab forward 4-8-8-2 ac-12 sorry i forgot that info in my reply.
Thanks trainman4, now for even more info you may want to drop down to the Model Railroader forum ! Here is really more for the O-gauge stuff, & over there is all N & HO scale help & very active too !!
Happy railroading & hope this helped !!
thank you will do,
