Just finished staining and painting my rock castings and have a problem. For the filler between the rock faces and for some flat rock areas I used drywall joint compound. The end result of color and weathering looks great, but when you look at the job at certain angles, there are diamond dust-like sparkles all over. This is even after dry brushing and chalk weathering. I tried a very very light wash of airbrushed flat white paint, but no good…still sparkles. How can I knock down the sparkles and still retain the finish on the rocks? Could I try a lightly applied acryl dullcote dusted on w/ airbrush? I spent about three hours getting these rocks right…I’d hate to start over. Thanks so much ----Rob
If the sparkles are from beneath all the covering you have added, and still interpose themselves, then you will have to to an opaque layer of acrylic, probably very light gray, and then re-stain.
Say it’s mica. It’s all over the place in granite rock formations. Tell people how hard you worked to model the mica. They’ll be impressed, both at your modelling skills and your knowledge of geology.
