Speaker Questions
Hello everyone,
I am in the middle of installing my first sound decoder, and have a few quick questions about the speaker:
  1. Where do I attach the wires for the speaker? I am using the QSI small oval speaker.
  2. What is the best way to attach to attach them? Solder?
  3. How should I glue the speaker and enclosure to the frame of the loco?
Thanks,
sfb
There are two small solder pads on the speaker to which you attach the decoder wires. The wires must be soldered, which is going to require a very fine tipped soldering iron. Don’t hold the iron to the speaker any longer than absolutely necessary to get a good solder joint because too much heat can damage it.
White, double-sided foam tape is a good way to fasten the speaker enclosure to the frame.
I use bath caulk applied with a tooth pick. Don’t get any on the cone. Take your time.
Gaskets for these speakers are usually sold with the speakers but many miss that.
Below is a good link with info about sound decoders. Look in Curriculum.
http://www.mrdccu.com/
The speaker should be in an enclosure or it won’t produce a very loud sound.
Steam or diesel install? There are different types of enclosures. Usually with steamers, the speaker is in the tender. The tender shell should seal fairly tight.
Many diesels, the shells fit tight. Some use a baffle with the speaker in the diesel shell. I have some diesels with both arrangements.
Below are some links about speakers. Probably more than you want to know.
http://www.youtube.com/watch?v=EslMEFmxKpw&feature=relmfu
http://www.youtube.com/watch?v=0U-ZDxIZkec&feature=related
http://www.youtube.com/watch?v=6zfuBNJyvlM&feature=related
When looking at the You Tube links, you will no doubt see more links that will interest you. Store all links in Favorites.
