Disclaimer: I don’t want photos of the locomotive’s demise to be posted in this thread, I only want to discuss technical specifications of it!
Okay now, if you have a knowledge of the history of Steam Preservation you’ve probably came across the plight of Richard Jensen & his locomotives (Specifically the GTW 5629) while the story is somewhat well known in our community, certain aspects of 5629 are not talked about that much if at all.
I believe the K4a had Worthington BL and K4b Coffin FWH.
Air compressor type was likely a Westinghouse cross-compound type; I don’t know the size and am not expert enough to know from photographs. I would cross-post this to the MR forum, as there are modelers who would know this.
There have been a couple of good articles on the arrangement of BL over the years, including a very good detail discussion in one of the ICS courses on feedwater heat that used to be available for download free from the Web. (Apparently somebody didn’t pay Bluehost so you’ll have to ‘search the community’ to see some of the diagrams…)
The BL heater is that big thing behind the air compressor on the left side; it has all the little pumps for the heater in the one unit (and in fact they are all arranged to be run off a common vertical piston rod!) so applying a feedwater-heater system to a locomotive not designed for one could be done simply and then easily shop-maintained. Of course the weight distribution sucked and so did some of the mounting methods, so it is no particular surprise that later designs which separated the components were ‘preferable’.
Steamlocomotive.com says the capacity of the Coffin FWH on the K4b was “5000gph”. The only Cyclopedia I can access (1947) does not show Coffin statistics - only a diagram and some sample components - and only has the Worthington ‘improved’ BL-2 range, which brackets the stated number: the 2-BL is 3900gph and the 3-BL is 5400gph. The various pipe sizes are mentioned, but of course are unlagged nominal size so not worth much for taking measurements off images.
The improvement from BL to BL-2 occurred in 1929, so if you can download a '22 Cyc from Google Books you might see what the 1924 sizes were rated, and choose accordingly.
