I just picked up a Sprectum GP30 at the St. Charles train show and was very surprised that it does not look like my SD and my GP inside. I would like to put the same kind in as the SD which is a TS 1000. I’m thinking I can grind out enough to put the decoder in top. There’s almost enough room for the TS 1000 after I removed the head light board.
For the speaker the best place looks to be the fuel tank but there seems to be something hanging down from the motor.
Before I split the frame has anyone done this kind, and are there any better ideas?
That’s a very old, early version Spectrum with the split frame. There are brush contacts pressing against the inside of the frame for electrical pickup. The only way to get to them to isolate the brushes is total disassembly. One of those is probably what you see hanging down from the motor.
Sound is impossible without major grinding away of the frame and, in my opinion, is not worth the expense and effort.
Just one of the risks of buying stuff at a train show.
