I’m new to trying to speed match diesels in dcc, using just the 28 speed steps, on an NCE Powercab system:
My son has two of the Genesis SD90MAC-H engines, and I will have a larger fleet of Bowser SD40-2’s once they are all here (most -2’s on hand are plain dc right now but some do have dcc/sound). We now have some longer freight trains that will actually require two diesels to work together, so it makes sense to speed match the Genesis (Tsunami) units with the Bowser (Loksound 5) units.
To complicate matters, Athearn does NOT state dcc default settings in the manual, because it is written for more than one engine. The Bowser settings for Loksound 5 are CV2 (min voltage)=1, CV3 (acceleration time)=20, CV4 (deceleration time)=20, CV5 max voltage = 255, CV6 (medium voltage) = 88.
The Bowser units run extremely well at slow speed, run slower at most speed steps, and are slower at the top end, with nice smooth accel/decel, too. The Genesis units are racehorses by comparison, and clearly have NO accel/decel time, so I set them to match the Bowser at 20 (after playing with other settings). I lowered min voltage on the Athearn units to 0 because they move at speed step 1 and the Bower doesn’t move till speed step 2 (which I apparently cannot find any adjustment that will start them moving at 1). I lowered (Athearn) max voltage to 190 and medium voltage to 60. This all was after 2 hours of playing around with them trying to get them to match.
So after 2 hours I have adjusted the Athearn settings to max voltage 190, medium voltage 60, accel/decel time 20 each, and min voltage 0. They will run together now, but I think I can still make some minor adjustments. As speed is increased to step 28 the Bowser unit starts to pull away slightly, but at slow speed the Genesis may still be a little faster.
I’m trying to get them to match as evenly as possible at all speed steps.
Is there something I am missing?
