Well after how many years here, I finally was able to scoop up a Lehigh Valley ST2. Some assembly required.
Looks like a much modified Fairmont “one-lung-er” M-19 from here.
Hopefully you got the stamped builders plate.
No, unfortunatly only have the SN off the motor, but the price was right.
Waukesha? Tecumseh? Briggs & Stratton?
Gotta get a bigger parking lot yet?
Now attach to it a small jet engine.
Where we are going we don’t need rails!
Adrianspeeder
Patience is a virture, congratulations and hope you enjoy it.
SOME assembly required? Should be a blast when you’re done.
Just assembly, not fabrication?
When you get it done, maybe you can come up and run it on our line - NARCOA has done a couple of days of runs here for the past couple of years.
Yup, lots of welding and torching on this unit soon.
Oh this will be a slow one for sure. I’ve only been home in total less than a month this year between all the trips.
Anyway, this will be a slow restore due to only being home less than a month in total this year between trips.
Adrianspeeder
Adrianspeeder, Enjoy your one month per year re-construction. A major project, but definately worth the effert. Thanks for serving in USAF and supporting our country. One of my God-sons is 14 years in USAF, a major in A-10s and my dad was a bombardier in B-24s in the 380th BG 1945. I’m a hardcore USAF fan!! Enjoy your project and thanks again. Bob
So, Adrian, You drive your Speeder to wherever they need the grass mowed (per last photo?)…Sure looks like a lot of blades need sharpening! [:^)]
I believe it is an S2, not an ST2. Good luck with your restoration. I have an ex-Algoma Central M19 that I ran on NARCOA meets from 1990 to 2000.
Cool! I was told the two speed transmission makes it a T. Adrianspeeder
Yup, but high grass stays greener in the heat.
Adrianspeeder
Did you also build a time machine out of a DeLorean??
If it has a transmission it is indeed an ST. Looks like it has a pully for a belt drive. I didn’t realize any belt drive cars had transmissions. Maybe the ST series cars do. MT series cars typically have Onan engines and transmissions while M series have Fairmont engines and belt drive without transmission.
Well, then look on the positive side. You will have a retirement project waiting for you.[;)]
