I’m over visiting from tne Model Railroader forums to see if I can help a friend that has recently gotten the model railroading bug, but has not yet found the value of the forums.
He has been running his mostly Lionel layout with a ZW transformer. He recently aquired an MTH Challenger. He says when he tries to run it, he barely turns the power on and it flies around the layout.
Any thoughts, experiences and suggestions would be greatly appreciated.
Sounds like the speed control has been disabled on that MTH engine. Your buddy needs to get a modern transformer, and perform a factory reset. Should correct things.
Thank you for the ideas. He evidently does not have a more modern transformer and he tried to do a factory reset. The ZW is listed as compatable in his material.
Were ZW’s ever upgraded ao that his could be an older model?
