SP's Zipper "Rider Coach"
In the 1940s and early 1950s, SP ran the Merchant’s Overnight Express (the “Zipper”) from Los Angeles to San Fransisco (and vice versa), Trains 373 and 374, usually with a Daylight GS-4, nominally 20 - 40 black Overnight Boxcars, and a “rider coach” on the end. I’ve seen two pictures of the train with the coach but I can’t determine what type of passenger car it is or the color. Does anyone have more information? I am trying to model, in HO, a prototypical train and I had assumed the end was a caboose. Also, were all the Zippers carrying a “rider coach”?
Thanks,
Mark C.
Thirty-four hours can be a long time, Mark – I know!
If you’re not getting any action on this web, you should consider posting your request on some of the forums that are more specifically devoted to model railroading.
Good luck!
Allen,
Thanks, I posted on the Model Railroader forum and got an answer in about 12 hours. I suspected that the TRAINS group would be the better source, but the MRR guys won out. Apparently a coach was used as a caboose since their wheels were rated for the speed of the train (60 MPH) and the wheels of a normal caboose were not. No passengers. (I thought it might be for moving around crews, not paying customers, but apparently that was not the case.) I have a reference and enough info to chew on.
Thanks.
Mark C.
Also, crews used to sleep in cabooses. Even today, when a passenger train needs employees to hang around awhile, a “dormitory-baggage” car is used. I don’t know how often this is done or what the union/RR rules are, but I saw a dorm-baggage car right hehind Amtrak loco no. 518 when the westbound Southwest Chief blew thru Galva, IL, on July 2 at about 5:20 pm.
