Does anyone know where I can get a reasonably priced square punch? I’m thinking that if I had a square punch, it would be easy to punch out holes in plastic walls for windows & doors. Just draw the square for the window, punch out the corners then connect the squares.
Ideally, I’d get a set of them the same sizes that I typically use for windows… but that would be WAY too expensive.
I’ve looked at some hand-held ones but they don’t seem to reach very far into the plastic sheet. I’d like to have at least a 4" reach to be able to do a three-story building.
I’ve use one of these mortiser bits, without the auger, to cut window operings - just position it and tap it with a hammer. The 1/4 inch size is pretty good for HO scale windows. You may be able to get a used one from a cabinet or furniture shop. New, they are pretty pricy - like $40. Sources are rockler.com and woodcraft.com
I got mine (used) from the wood club I belong to. I even made a handle for it.
I have the Micro-Mark punch and used it to cut nearly 100 doors and windows out on wood and plastic when I scratch-built a western town. It works very well.
Exactly how do you use them? My brother-in-law made one for me but I really can’t seem to get satisfactory results. It is perfectly square (90 degrees) but I’m missing something using it.
Do you use it on a block of scrap wood or something like that?
Mount it in the chuck of a drill press. Use it with the drill press NOT running. Place a smooth block of wood on the back side to keep it from breaking through the wood.
I used it both in a drill press and by tapping it with a small hammer. You need something under the material to act as a cushion, such as a scrap of 2x4 pine; and don’t cut all the way through with the punch. Finish the cut with an X-Acto knife and straight edge.
