St Lawrence Warehouse - Montreal
Hi everyone,
Has anyone built or know of anyone who has built the St Lawrence warehouse in Montreal? It is an iconic Montreal landmark (images attached)
Thanks
https://www.google.ca/search?q=st.+lawrence+warehouse+montreal&biw=1344&bih=695&source=lnms&tbm=isch&sa=X&ei=LuwhVfG8K8bOsAWn24GAAQ&ved=0CAcQ_AUoAg
MichaelL
Looks like a really neat project!
It would appear from the unusual angles that it was built to maximize the usable space available. That is a scratch builders dream.
I hope doctorwayne chimes in because he has built some excellent buildings very similar to what you want to model. His methods are top notch.
Dave
Hi MichaelL
Well that is a very interesting looking building.
Never built anything like that.
I try to stick to simple square or rectangle buildings.
My attempt at an odd shaped one failed so when the courage is up again will try again.
If I was going to given its very large size and odd angles I think my first step after finding enough information would be a foam core board mock up
once the mock up was the right size and shape and reinforced for strength I would overlay the sides building up the details, foam core is cheap enough but I would not want to waste it given the large size that building would be.
I would only open up the windows if in the forground even then I might just stick with paint and acrylic gloss clear for the windows with the frames stuck over it.
Just a few thoughts.
regards John
