My son and I are gang to hae a staging area behind a wall and we were wonering if we should or should not lay foam doon as we will with the rest o’ the layoot?
Please excuse the type’en - the Scot is coom’en oot again and I need to get this done afore my client for a photo shoot shows up.
To me it’s a question of noise. In my last layout one section was laid on plywood and the rest was laid on foam. The difference was deafening, so to speak. I’d put down the foam.
I didn’t use roadbed either, but the track is on foam.
May staging is in another room and the section between the pike and staging (about two feet going through the wall) is plywood. You can hear the train a coming…
Personally, I like using foam and would suggest it everywhere.
