I have been building my current large basement layout for over 20 years now. While I think my overall design was a good one, I made one major mistake which has been a continued source of aggravation and frustration and I have finally decided I can’t live with it any longer. My layout is an around the walls dogbone with the double track mainline gaining elevation as it moves westbound and the end loops are stacked in one corner of the basement to save space. Each loop is triple tracked and the loops serve as staging yards. The problem is I didn’t create enough vertical separation between the two loops. Access to the lower loops is difficult and when there is a derailment, it is a nightmare. I need to do something with the upper loops to get better access to the lower loops.
One idea I’m considering is replacing the upper loops with a stub end staging yard and a single loop for turning the trains. This is similar to what John Armstrong proposed in his book Track Planning for realistic operation. The stup end yard would be on a 2% grade so arriving trains would head into the yard going up the slope and would back out of the yard going down slope and then get turned on the single track loop.
My concern is the reliability of backing long trains out of the yard. My thinking is that by doing the backing move down grade there is less chance for a derailment as gravity will help pull the cars downhill. My longest passenger train is the Walthers 20th Century Limited set with 9 full length passenger cars and two E-units. My longest freights would be of a similar length. The trains will be backing out of a yard ladder and I’m wondering if that is going to be a problem.
Has anybody else used a track plan that required backing moves with long trains and how reliably can that be done?
As a candidate for captain obvious the lower level could be lowered or the upper level raised. if you wrapped the lower level with a helix you could somewhat easily raise the upper level allowing inside access to the lower level. That assumes that the return loops are not large enough to put a helix inside the loops which would be better access. Alternately you could rebuild both outside a helix. it shouldn’t take more then a loop or two on a helix to gain sufficient separation.
It’s almost 6" now. I would have to gain significant elevation to make a difference. The upper loop is in an area about 8’ by 14’. One of the other options I am considering is to make a completel loop of that area to gain elevation. It would became a large single loop helix if I did that. My calculations tell me that the added loop on a 2% grade would gain about 7 3/4 inches.
Another option would be to move the lower loop and lower it so it runs under the approach to the upper loop. If I were to do it over again that might be the best option but I would literally have to do it over again because of the drastic changes to the bench work.
Before considering either of the above two options, I’d like to know if backing long trains out of the ladder is a viable option. It would require the least changes to the existing bench work and the least amount of additional track.
Your reply posted while I was typing my reply to dehusman and I discussed these options. Either of the these options is going to grab the space currently occupied by my workbench. I have a space I can move that to if necessary. One of the other drawbacks to either is that it is going to create a lengthy duck under which at my age is an important consideration. I already have to make a short duck under to get inside the loops and these options would extend that.
What radius are your curves? At 36" radius I have never had any issues backing long trains. A friend had a stub end staging yard behind a backdrop and backed 30 car trains around a 30" radius to park trains.
You have seen my new layout plan, I will be backing trains around both legs of the wye to turn them and to back them into the staging. The staging tracks are about 20’ long, 35 to 40 car freight trains.
I have done this before, and have no concerns about my design.
I do have a stub-ended staging yard and yes, I occasionally have trouble backing passenger cars through the turnouts approaching the yard. These are large radius turnouts and present no problems in the forward direction. I have trouble with very old passenger cars with Talgo trucks. This doesn’t surprise me at all. I have no problems with rolling stock like freight cars.
Not vertically, horizontally. Don’t change elevation, change alignment. Put the top loop against the wall and move the bottom loop 6" towards the aisle and 6" away from the end wall.
That’s just not feasible. The top loop is already against the wall and moving the lower loop out 6 inches would require realigniing the main throat into the staging loop which would require a major overhaul of the modeled portion of the layout. I’m not prepared to do that.
What might work is what I already wrote about which is to relocate the lower loop so that it runs under the throat to the upper loop. In essence I would be unstacking the loops. I have sketched it out free hand but I’m going to have to sit down with some graph paper and a compass to draw actual track radii to see if what I want to do will fit in the available space. I want to maintain a minimum 32" radius for all the tracks in any loop or curve.
That doesn’t surprise me. That’s why I’m thinking of putting the stub yard on a grade so when I’m backing out, gravity will be assisting the backing move so the engine isn’t pushing as hard on the train.
I have a long 1.75% grade that I could test a backing move with my longer trains but it doesn’t have the turnouts to negotiate so that isn’t going to tell me everything I need to know.
My minimum radius for my loops is 32" but that’s not the issue. I won’t be backing around the loop. I will be backing out of a stub yard. My current loop staging yards use #6 turnouts but normal operation never requires me to back a train around the loops. To get the stub yard to fit I’m going to have to stay with #6 turnouts and my concern is whether backing a long train through the ladder is going to lead to common derailments.
As I recall, the plan John Armstrong presented did back the train around the curve but I have to dig up my copy of Track Planning for Realistic Operation to see exactly how that worked. With a stub end staging yard, you’re either going to have to back the trains into it or out of it through a ladder and that’s my concern more than backing around a loop.
That’s good to know that you are able to back your trains into your staging yard. What size turnouts have you used in your ladder?
Sheldon
I would have no reason to back into the staging yard. Trains would head in, and back out.
UPDATE: I mentioned in the OP that what I was thinking of doing was similar to a solution in John Armtrong’s Track Planning for Realistic Operation. I based that on memory and wasn’t quite sure about the configuration of his proposed staging yard. I just located my copy of his book and see that what he proposed is not what I have in mind. In his plan, a train would head into the staging yard, then back up around a loop and then back into the staging yard. What I have in mind is a stub yard that trains would enter before going around the reversing loop. When it was time for the trains to make their return trip over the layout, they would back out of the yard and then go around the reversing loop. I have several options as to where to locate the entrance to the stub yard. It could be at the beginning of the reverse loop or after going part way around the loop. In either case, it would head in and back out which is why I could put it on a grade to allow gravity to assist the back up move.
My copy of the book is the 3rd edition. For those who have the book, the staging yard he proposed is on page 104. It’s an interesting idea but not right for my situation.
For those who have John Armstrong’s Track Planning for Realistic Operation, 3rd edition, page 124 shows a diagram of what I have in mind. My current set up is much like the top diagram minus the small stub yard. What I have in mind is much like the lower diagram except that I would have the stub yard go over the loop track rather than under it and the entrance to the stub yard would be from the other lead track so I could head in and back out of the yard.
I think its slightly different from the way most people think of staging. Your first move in an op session would be to back up the train and position it for heading down the mainline. I think most people think of staging as a place to reposition the train for the next session, and that repositioning would be the last move of the previous op session, not the first move of the new session. I don’t think it matters, its just a different way to think about it, IMO.
Hopefully there is enough space savings with the new design to fix the problem you have now.
Edit: I could see that if you had to back up each train before turning it to then head out of staging, it might interfere with a multiple-train time schedule. That’s why most would want to turn all of the trains (two loops stacked on each other) at the end of the previous session in order to have each train ready to go ahead of time and can leave staging immediately when it needs to leave. You might want to consider the impact this new design will have on the schedule, if it matters to your op session.
The reason for doing it the way I propose is the staging yard will be on a grade and I want the back up move to be down grade so gravity will assist in preventing derailments when a long train is pushed through curves or turnouts. If I were to have the trains go around the reversing loop first, they would be backing up going up grade and I don’t see anything good happening from that.
I’m looking at three options right now. One is the stub yard where trains would head into and back out of. Another would be
John-NYBW
This seems like a good solution.
