I have some 223 standard switches that won’t work with the controller. I switch the 222 switch controllers back and forth and nothing happens on the switch. GThe contacts on the switch I think are all messed up and out of sync or something. The light bulb lights up fine and does not short out at all. How should the contacts be aligned?? Is there a diagram somewhere i can look at online?? thanks.
When i apply power to the track the motor housing of 223 switch gets very hot!!! I think I have it wired up wrong. Anyone know the right way to wire these up internally, inside the switch. I got the light bulb working, thats about it. The 222 controller does nothing when i switch it back and forth. Please help, I need some sort of diagram that shows how to wire up these switches. Thanks.
