Standard 384E Questions!!
What does the 2 levers underneath the loco do?? There is one on the front and one on the back of the motor assembly. I know the one that you push up and down, up locks it into gear and down makes you able to change directions. The other lever on the other side of motor, it moves left and right, this I believe changes directions. What positions to i put these two lever to make my loco able to switch directions when i push direction button on my controller? Obviously up on the front of loco lever and the rear left and right one, i have no idea. any help is needed. thanks.
It sounds to me like someone added another reversing unit to the motor at some point, but I can’t really visualize the set up, so I may be wrong.
