I’ve been in this hobby for 60 years, and have seen “standards” established for a lot of things. Can any body explain why every manufacturer uses a truck mounting screw no one else uses? How about car bolster bosses? Couplers, same situation. Different retainer screws, different draft gear boxes. Different axle lengths. It is bedlam as far as the running gear of our trains is concerned.
This rant is generated by my installing code 88 wheelsets and replacing couplers if necessary, with Kadee 153s, or 156 on cars with cushioned underframes. Drop a screw and figure “Forget it, I’ll hunt for it later! I just use one from my stash, instead.” Not so fast bucko! You need a wierd machine screw with a shouldered shank, instead of a simple 2-56. Why?? There is no undo stress on HO scale rolling stock, that requires all of this exotic hardware. Could it be time to institute standards for truck and coupler mounting, with common sense deviations for special installations?
