Ah… Track planning in full size. I am right there with you. That is the only system I have to make sure it will all work when it is built.
-Kevin
-Kevin
How do you do a 1:1 scale mock-up with flex track I don´t know, but a well planned paper plan works as well, if you don´t cut corners and cheat on yourself when it comes to radii, switches and distance between parallel tracks.
We do have a ruff plan on paper to make sure it will fit the room.
I like how it is up on a balcony.
It’s on a balcony and will also be in one bedroom.
John
A scale drawing usually does the job so you don’t have to do a full sized mock-up. It’s worked so far for me with 3 layouts. Already have a scale drawing for the next made up.
That’s quite a long dive if anything is near the edge there!
John, I knew instantly when watching that first video that I did not like you because you have a table saw and I don’t. LOL
Nice work. Keep us posted on your progress.
Don’t feel bad Rich, there was an indepth discussion at another forum (which shall not be named) where a member asked if a table saw was needed to build a layout as he was a bit fearful of using one (table saws do require a great deal of respect). The consensus was that no, you don’t really need one. Those who did have a table saw definitely agreed, not necessary for layout building.
Even if I did have a table saw, I wouldn’t even be able to bring home a 4x8’ sheet in either of my cars; I simply have Home Depot or Lowes cut 4x8 down to a size I can use and fit in the car. (I can fit 10 long boards in my car and 30" wide by 8’ sheets, but not 4x8. I’d have to tie that to my roof rack but don’t bother when I can have it cut down.
My woodshop teacher taught us a healthy respect for table saws back in high school many moons ago so I’ve just gotten by without one and it’s been no problem.
For what it’s worth, I built my last layout using only 2 power tools, because I was on a budget: a sabre saw and a cordless drill. It was certainly with a little care.
Since budget has now allowed, this year I added a compound sliding 10" miter saw and a circular saw. The miter saw I would expect will speed things up this time around.
I’d say those four power tools are very useful in layout building:
As corner frame jig is a big help for attaching 90 corners f
Why not use a free track software planning tool before going to the actual layout? It’s much easier/faster that way. Once you have the paper, putting it on the layout is easy–create a grid system on the foam, wood, etc.
Rio: I only have a cordless drill. That’s the only power tool, you really, really need. Home Depot and Lowes can cut wood pieces. Also, my local Home Depot does rip cuts, so I can get 4x8’ stryene sheets cut to make fascia. For those who use foam, there’s no need for those saws.
Memo to riogrande and rich…I was born with 10 fingers and I intend to die with ten fingers. I stay away from table saws and routers. I did just fine with a compound mitre saw, circular saw, drill and jig saw when I built my layout.
Like any power tool, a table saw requires the utmost in safety practices, proper clothing and eye protection, absence of distractions, etc.
I use my Miter saw’ or some call it a chop saw ect more than anything. Also 2 cordless drills. I use drywall screws for everything’ makes building and taking apart easy.
No arguments from me. The four power tools you listed is all I have.
The last layout I did only have a drill and saber saw. Home Depot did all the major cuts on the 4x8 sheets but the Saber saw ie jigsaw, did all the rest.
Kask, I double dog dare you to build my last layout with only a drill. I’d be happy to post photos. Sure, Home Depot cut my big 4x8 sheets down but there were many many other cuts to build all the open grid framing and more. I think HD would have thought I was having a laugh if I asked them to make all those cuts too! [(-D]
I’ve built 2 layouts using only a power chop/mitre saw to cut the x3 or x4 sticks. I let Home Depot cut the plywood. Yes, the layout ends up having square shelfs but that just leaves more room for scenery than carving out a different shape.
If I wanted the plywood to curve in places I assume the only tool to use would be a jigsaw.
As for assembly, I use a hammer, finish nails, and yellow glue as well as a power screw driver/drill.
For sure the big 4x8 sheets are easiest to have cut down at Home Depot or Lowes etc. such as the large flat yard areas:
Heck, even if I had a table saw, I can’t get the 4x8 sheets home since neither car will fit them. But I can fit in a 30" x 8 foot sheet.
A mitre saw would definitely speed things up vs a sabre/jigsaw. The down side to a mitersaw only without the jigsaw is cutting the sub roadbed curved pieces such as in the photo:
Conversely, a jig saw will let you cut the 3x and 4x frame pieces as well as the curved pieces, which is why I was able to build this layout with only the drill and saber saw.
Nails will work of course, but drywall screws are great because it was a snap to disassemble the layout down to bare benchwork components when it came time to break it down and move.
I simply backed out the screws and took things apart and saved everything including the screws.
[quote user=“riogrande5761”]
Doughless
We tried use one but working with flex track on it was difficult.
