I am tryinq to aplly Static flock grass from Woddland Scenics, but I don´t have a special Tool.
Any body use this material? How can I?
[#welcome] rcarras2
Here’s an article that may help
http://www.ztrains.com/pages/workshop/static/static.html
This suggestion from underworld was taken was from an eariler thread about Static Grass Applicators.
I know this sounds dumb but it works.
Apply the glue (I use Noch Grasleim)
sprinkle on your static grass, not too heavy but not too sparse
rub the balloon back and forth on your head
hold the balloon almost touching the applied grass. It stands right up
OK, Ray. Now we need to know whether you’ve got a Beatle haircut or more the MIchael Jordan variety. That’s a very useful and simple technique. I can just imagine my daughter’s teenage friends watching me do that.
Yeah! I can too. What a hoot that would be.
Just your basic short haircut. If I still had my big 1980’s Paul Stanley hair, it would make an awful mess!!
[:D]
That’s the deal with getting older. You get hair in places where there was none before and no hair where it has always been [|(].
If you lack hair on your dome, try using a wool scarf or sweater after it has been in a dryer. (Omit the drier sheets)
Or, if you have some extra foam board lying around rub it with a wool cloth, and then hold the foam over the grass. It’ll do the same thing as a balloon
Here is a page on how to construct an applicator (in German[:)])
http://www.finescale.org/howtos/elektrostat/elektrostat.html
I’m not to scenery yet, so I haven’t tried it myself.
Cheers,
Rod
I have been looking for that diagram for weeks, But I don’t read German. Any help out there?
This is strange, I’ve been considering using static grass on my N layout and was wondering how best to apply. And viola, you guys magically appeared with advice. Amazing! Thanks for offering up your knowledge to us novices.
Ok Thanks for your help , I will transalte the diagram (germany) and I will put in the Forum
Tahnks All
The baloon is a lot cheaper than the 250.00 Noch wants for the alien machine
$116 at Scenic Express …
http://www.sceneryexpress.com/prodinfo.asp?number=NH60130
[swg]
–Joe Fugate__
Joe I have a question for you,do you know where I can get conductive paint! or conductive epoxy ??? I need to put a cam on the driver wheel of 2-8-2,last try I got the wheel a little to hot and warped it!!hot sodering iron don’t work so good
Thanks
Jim[:-^][:D][xx(]
Jim
Any good electronics store (not Radio Shack) should have it. Or try
http://www.action-electronics.com/gcelect.htm#Paint
sorry to have to revive an old thread but i have tried the balloon method and the palmolive bottle method but neither worked. the bottle was a no goer - just blows the grass around or lays flat on the glue. and the balloon static lifted loose grass which stuck to the balloon but certainly didnt make any of it stand up. have tried several types of glue and varying stages of tackiness from wet to almost dry. any suggestions would be greatly appreciated. thanks
thank you for that info harold. your method certainly gives a good look. i will be down to the shops to hunt for suitable materials and give it a try.
