Steam Engine Driving Wheel Center
Greetings from Russia!
What is the difference between Boxpok driving wheel center and Scullin driving wheel center? Is it correct to say Boxpok & Scullin driving whrrl senters are the disk driving wheel centers?
Valeriy.
Boxpok and Scullin drivers are the common disk driver center designs. Visually, the scullin design appears more solid, with only a few comparatively small circular holes in the visible surface. Boxpok drivers have large egg-shaped holes, almost like the spaces between the spokes of a conventional spoked driver, but with circular rather than square ends.
It’s interesting to note that, while disk drivers were considered more ‘modern’ than spoked drivers, the last locomotives built for mainline service in the United States all had spoked driver centers rather than disks.
One aberration that showed up toward the end of steam was the installation of disk main drivers on older locomotives, with the other drivers remaining the original spoked variety. I presume, but cannot prove, that this was done to correct for worn out main crankpins.
Chuck
Thank you, Chuck.
Yes, I know that N&W last steam engines (J class, A class, Y6b class) had spoked drivers. I hope it is interest for you, but the last steam locomotives in Russia (L class, LV class, P36 class) had only disk drivers.
Please, visit http://home.earthlink.net/~steamloc/
This is Atlantic Coast Line R-1 4-8-4 by Baldwin. Note the type of driving wheel. Is it boxpok or spoke driving wheel?
Valeriy
The ACL 4-8-4 had Baldwin disc drivers.
There must be lots of pics of Scullin drivers, and you’ll see they’re unmistakeable.
Boxpok drivers usually had the egg-shaped openings, but sometimes the openings were larger-- four large near-circles. Some NP 4-8-4s, for instance.
Boxpok drivers with four large almost-circular openings were pretty much standard on later Japanese steam, starting in the late 1930s. The only exception was the E10 class 4-10-2T, which had ‘conventional’ Boxpok drivers.
Classes of locomotives which were first produced earlier [C56 (2-6-0,) C11 (2-6-4T) and C12 (2-6-2T) classes] were built with spoked drivers until they went out of production, as late as 1947.
Chuck
Quoting from page 71 of author Robert J Church’s The 4300 4-8-2’s, Southern Pacific’s Mt-Class Locomotives from Signature Press, publisher: “The main driver received the piston thrust along with the reciprocating forces of the side rods. If a cracked spoke occurred, it was usually on the main driver. In 1946, it became standard practice to replace defective main drivers with “Boxpok” (General Steel Castings) or “Universal” (Locomotive Furnished Materials) disc wheel centers which were much more durable. But spoked main drivers were only replaced if flawed, so many locomotives retained all spoked drivers until they were scrapped.”
Mark
Well Mark.
To my regret I have no this book in my home library. I know Boxpok driving wheel centers by General Steel Casting Corporation, driving wheel centers by Scullin Steel Co., welded driving wheel centers, Bullied Firth Brown boxpok wheel senters, of course spoke type driving wheels, but I never searched information about universal disc wheel centers. What is the design of this type? Do you have a picture of universal wheel centers?
Valeriy.
The book has photographs showing Boxpok and Universal disc drivers, but the photographs are copyrighted by others. They look very similar to me except the Universal type have larger holes. My untrained eye probably wouldn’t be able to distinguish between the two types unless both were available to compare side by side. (Hey, the Universe is bigger than a Box!)
Mark
Anybody find a better pic than this of Sheeler’s painting?
http://www.flickr.com/photos/washingtoncitypaper/2515652901/sizes/o/
The 5450 is a good example.
http://www.rr-fallenflags.org/nyc/nyc-s5450ao.jpg
The ATSF class 3400 were rebuilt with Universal 79" disc drivers.
http://orion.math.iastate.edu/jdhsmith/term/slusatsf3415.jpg
The openings were more “triangular” and were larger than those in BoxPok wheels.
BoxPok is an abbreviation for “Box Spoke”.
M636C
The ATSF class 3400 Universal disc drivers looks like NP 4-8-4 class A-2 #2651 driving wheel centers (see p. 103 Steam`s Finest Hour by David P. Morgan), Chicago & North Western Railway 4-8-4 class H-1 #3055 driving wheel centers (p.94 Guide to North American Steam Locomotives by George H. Drury) or Chicago Great Western Railroad 4-6-0 class E-7 #507 driving wheel centers (p. 109 Guide to North American Steam Locomotives by George H. Drury). Is it Universal disc drivers?
Valeriy.
I don’t have Morgan’s book, but a photo of 2650 on display in Chicago in 1934 appears to have BoxPok wheels. These Boxpoks have large circular holes, but they don’t have the raised lip around the hole that all Universal disc wheels have.
These look to be the same as the drivers on NP 2650, and are BoxPok discs with large holes
Finally, yes, these do indeed look like Universal disc drivers! They appear to have the raised lip around the hole that was a feature of Universal disc drivers. This I think can be seen in the photo of ATSF 3420 on page 21 of the Guide to North American Steam Locomotives by George H. Drury. The holes in these Universal wheels are actually smaller than in some Boxpok wheels, but the appearance is different.
Very good information on Universal drivers, made by the LFM company, are given on pages 206 to 210 of “Santa Fe Locomotive Development” by Larry Brasher.
Santa Fe used Boxpok and Baldwin Disc wheels on new locomotives but used Universal wheels on locomotives they rebuilt, possibly because LFM was a local business in Atchison Kansas.
Russian BoxPok diving wheels were different from most US Boxpok wheels in that they had fewer larger holes, like those Boxpok wheels on NP2650 mentioned above.
Russian BoxPok wheel designs were used on the Chinese
Do you know the “birthday” of Universal drivers?
We have no this term “BOXPOK” in Russia. Our technical literature used only one term “DISC DRIWING WHEEL CENTER”. So, all our steam engines (Class L, class LV, class P36) has disc driving wheel centers (I think because we have no different kinds of disc driving wheel centers).
I found the image of Luisville & Nashville 2-8-4 Class M-1 with wery interesting driving wheel senters on page 128 Locomotive Cyclopedia of American Practice (Thirteenth Edition - 1947). You may see not so better photo on this link:
http://www.lnrailroad.net/lnp12.jpg
I think this is spoke type driving wheel, is not it?
Valeriy.
His pic is one of the first order of L&N 2-8-4s, Baldwins that had drivers with those “webbed” spokes (for lack of a better word). Steam’s Finest Hour only has a pic of the later 2-8-4s, with Boxpok, but that other circa-1960 Kalmbach coffee-table book, MR Cyclopedia Vol 1, has pics of each.
In his Santa Fe book, Brasher illustrates ATSF Pacific 3401 in July 1935 with a pair of 75" Universal disc main drivers which he thinks was the first example.
A number of webbed driving wheels were used by the Pennsylvania Railroad, possibly supplied by Baldwin.
There were other types of modified spoke driving wheels:
In Western Australia driving wheels with “Y” shaped spokes were used from about 1939 where the fork of the “Y” was at the wheel rim to give more even support.
Also in Australia from about 1948 a design known as SCOA-P which used a spoke of “U” cross section was used. The open side of the “U” faced outward giving the appearance of twin spokes.
The Russian disc wheels are clearly copied from the BoxPok design rather than any of the alternative possibilities, so I would prefer to call them that, even though there were no other types used in the Soviet Union era. The comparison with the Chinese and earlier Japanese copies of US Boxpok wheels also used in China is interesting and informative.
M636C
I forgot I have Kalmbach Cyclopedia Steam Locomotives by Linn H. Westcott seventeenth printing, 2004 in my home library. You are right. There is L&N 2-8-4 class M-1 with BoxPok driving wheel centers (page 88) and the same steam engine with “webbed” driving wheel centers (page 89).
I found one interesting picture of PRR 4-6-2 class K4s with 3 different driving wheel centers: spoke type, boxpok type and “webbed” spoke type (see page 141)!!!
Valeriy.
Universal disc drivers prodused only Locomotive Furnished Materials or another producer (such as Baldwin)?
Valeriy.
I think that the “Universal” name was a trade mark of LFM and only made by them. The oldest Universal drivers had smaller holes spaced further from the centre, and are seen on the earlier ATSF rebuilds.
Baldwin had their own design the “Baldwin Disc”.
General Steel Corporation made the “BoxPok”, but GSC was half owned each by Baldwin and Alco, so Baldwin had some ownership of both Boxpok and Baldwin Disc designs.
The Kalmbach “Locomotive Cyclopedia Vol 1” is a good reference. There are some errors in the text and in the drawings, but the photographs are just great.
M636C
What is Baldwin disc design? It looks like B&M 4-8-2 #4117 (p. 191 The Kalmbach " Cyclopedia -Volume 1 Steam Locomotives by Linn H. Westcott) or ATSF 4-6-4 class 3400 (p. 208 the same book). I am interested in “webbed” driving wheel centers. Is it Baldwin design?
Valeriy.
