Other threads and questions have prompted this posting. I’m going to state what I think I know about basics, and then invite the experts to elaborate and or correct. I hope this can develop into a thorough and educational discussion that will cover all types of valve gear from the earliest Stephenson through to Franklin and Caprotti and whatever. Also, if someone can post a good figure for the difference betwen slide and piston valves, better explained in a drawing than by words, that would also be a big help.
Valve gear has two purposes, to reverse the locomotive, and to determine the duration of steam entrance to and exhaust steam exit from the cylinder during each stroke. This is done by its control of entrance and exhaust valves from motion of the rotating driving wheels.
Steam is used most efficiently if it is admitted to a cylinder when the volume between the piston that cylinder end is near or at minimum during the power stroke. However, the greates possible power is provided when the intake valve is open for a substantial part of the stroke, not just the start when the volume is minimum. So there is a trade-off between power and economy. That is why starting a heavy train is usually done with long cut-off, and running at speed with short cut-off. However, use of short cut-off can, as discussed on other threads, provoke highspeed slipping.
Exhaust valve control seems optimum when it provides minimum back-pressure and thus minimum wastage of power. This is when the exhaust valve is open for nearly the entire stroke on the exhaust side of the piston. This is impossible to arrange with slide valves, where exhaust and intake valve openings must be the same proportion of the stroke and is arranged only with great difficulty with piston valves. There is also the question of the effect of reduced back-pressure on smokebox draft.
I hope the real experts will continue this discussion. Thanks
