I would guess that steel banding started in WWII. I expect both flats and gons were used–both would be roughly equivalent. The big difference is you can use a fork to unload a flat. I would also think that loads of steel in gons would be blocked in place (in addition to any banding). For both gons and flats, there’s be blocking under the load so a strap could go under for lifting.
