Stone wall in HO scale, webpage?
I need a stone wall in HO scale. Can someone please point me to a webpage with lots of walls? It should have a structure like this picture, the color does not matter:
I used Google’s image search function with the key words “stone wall” and found any number of useful images, but none that closely resembled your wall of choice.
Similarly, a conventional search using either “stone masonry” “stone mason”
or “stone wall how to” turns up a lot of information, but not what you’re seeking.
I’ve found that the best resources on stone walls can be found at my local library. Sorry that I couldn’t provide a more direct answer on this one.
-Ed
Your best bet is probably going to be to make your own mold. It’s fairly easy with some white glue and RTV. Do a search on “making molds” in the forum. I’m sure someone has put it out there.
Google “HO scale stone wall”.
That should give you lots of choices of stone walls. Here is the first URL that came up with that search: http://www.cccrow.com/main-pages/scratch-list.html
I didn’t look at any of the rest, although there are a bunch of them! As Medina1128 says, making your own molds is easy, but you need a sample of a rock wall to make the mold from.
Hope that helps.
Darrell, quiet…for now
Try here.
http://www.jeffreywimberly.proboards100.com/index.cgi?board=nscale&action=display&thread=1156345579&page=1
