iS IT OKAY TO STORE THIS TYPE OF COMPRESSOR IN THE GARAGE SINCE i DON’T HAVE TO MUCH IN THE BASEMENT? RAMBO1…
What type are you talking about? If it has a tank you may have a problem with moisture freezing in the tank. Draining it before storage should fix that problem. The compressor is probably small enough that it does not have oil in the housing that would get stiff.
Most compressors like yours spend every night and weekends in the bed of a pickup truck (mostly with camper shells, but many times without) year around. I draw the line at letting them get rained on, but as far as cold goes, the only problems we ever have is when the mointure freezes in the line (usually at a joint or other fitting), much more common below zero farenheit.
To your compressor, a garage will feel like a castle.
