The decoder is an MRC, purchased before I was aware of all the MRC problems. Decoder is installed in an Athearn D-9, ready to run. Power is a Zephyr system. Motor control is OK. Sounds are OK.
The problem: When I put it in forward, and press FO, the headlight comes on at normal brightness. As I open the throttle, the engine begins to move, and the headlight begins to dim, going all the way out at speed. Further confusing the issue, when I put it in reverse, the backup light is barely visible, but gets brighter as I open the throttle. Why would the lights get dimmer going forward, and brighter backing up? I’m just wondering if any CVs might be involved. Given that it’s an MRC, maybe I should be grateful the motor and sounds are OK. But it would be nice to have the lights work properly. Thanks for any help or clues.
