I have a CI switch stand with the electrical switch to power the frog. The switch is a curved Shinohara #6 (I think) with both sides of the frog insulated. The middle electrical connection of the CI switch stand is connected to the isolated frog area.
The first indication that I had a problem was when my 0-6-0 stalled entering the switch from the diverging track. I checked the engine over, cleaned engine and tender wheels as wells as the electrical pickups. Oddly the loco runs perfectly through the switch on the “closed” side of the switch.
Anyways, I got out my VOM and measured AC voltage (Zephyr DCC): everything measures about 14.5 V. EXCEPT at the frog area only when the switch is thrown to the diverging side. There the voltage is between 6.0 and 5.5 V.! Yes, I do know that the Voltage I was measuring is not exactly correct. I have no idea how the voltage at the isolated part of the switch could be 2/3s of normal, and I’d like to hear theories as to how this might be so.
I replaced the CI switch stand with a new identical unit, and voltages measure around 14.5 V. everywhere. Before I removed the defective switch stand, I removed the little copper thingy and burnished it bright, as I did for the three-prong electrical connections. I checked all the electrical wiring with a continuity tester, including having someone pull on the wires while I was testing to see if one of them was loose. All were solidly connected.
