Hello all,
I’d renumber one locomotive.
One 4 unit consist I run is all GP40s. 3501, 3502, 3502 and 3507.
One of the 3502s I renumbered 3503.
I haven’t gotten around to actually stenciling the new number on the cab so I took a piece of tape and wrote the new number on it and put it on the top of the cab.
I could have also renumbered it in any one of the open numbers in that sequence; -03, -04, -05,-06, -08, etc.
Because these unit are run in an MU I could have done a simple consist and renumber all of them the same number.
Occasionally I breakup this consist to individual units so having a unique address is necessary.
I also had a GP38-2 with an overlapping number.
Through research I found out that this original number was the prototypical number- -3503, but this number had already be assigned to one of my GP40s.
On my roster 3500 series are GPs for one particular railroad. Rather than going back an reprogramming all the GP40s I just renumbered this unit 3524.
This number was chosen for no apparent reason other than it was in the 3500s and gave me some wiggle room if I expand my GP40 roster for this railroad.
Again, I used the tape patch-out method until I can get around to renumbering this unit.
Finally I have another GP40 from a different railroad.
I was railfanning in Colorado Springs, Colorado, and saw a prototypical unit with the number 1411 from this same railroad.
Once I got home I renumbered this unit to the prototypical unit and used the tape patch method to designate this unit.
Hope this helps.
