One thing I haven’t figured out yet is how I should set up my addressing for detection, turnout control and locos. I have a multilevel layout with the Digitrax Super Chief to be connected to JMRI via the Locobuffer USB. I have placed a panel with detection boards and switch motor drivers (all RR-Cirkits) on each wall to handle the devices on that wall on all levels. My reverse loops are controlled with PSX-AR’s. I am starting to set up the computer to run JMRI today.
Obviously the first choice for locos would be to use the cab number as the address, but what about the other devices? How do you come up with a standard that allows you to instantly identify a device by it’s address? Do the other devices share the same address range with the locos (I’m afraid of coming up with a standard that would cause me to assign a SMD the same address as a loco).
The other thing I’m not clear on is the sequence of events. It seems that Layout Editor in JMRI prefers to have the BOD’s and SMD’s already known to JMRI before placing them on the panel. Also all of the RR-Cirkits devices start with the same address so they need to be added one at a time. What is the correct order of the steps in installing, wiring and defining all of this?
And lastly, I’ll have the computer, command station, and the RR-Cirkits devices. When I get it all set up, what it the correct order to power it all up?
