String Lining
In the 19th Century ‘Engineers’ did not have finite knowledge of the materials they were using to build their creations - the basically adhered to the adage - If a little gets the job done for now, a lot more will keep doing the job for a lot longer. Engineers of that age wanted their creations to last ‘forever’.
Mid 20th Century and later engineers now have strength specifications on virtually every material they use for their creations - they also know, in most cases, they are designing for a 50 year life span - not a ‘forever’ life. As such they design accordingly. These engineers are more cost concious than they are longevity concious.
Sometimes “improved” material did not give better longevity. If I remember Steinman’s biography correctly, he mentioned a great use of hardened steel wire in the wire rope and cabling used in suspension-bridge construction in the post-WWI period. This came to grief in much the same way nickel boiler steels did.
The bridge cables in Quebec are more victims of neglect than “postwar technology” design. Part of the fun is watching the shucking and jiving at upper levels about who reported this issue and when, with a certain ‘wait and see’ attitude entirely objectively unjustified.
It’s almost to the point they can’t pull cables for replacement without risking an accelerated load shedding leading to span collapse.
Perhaps that spot is haunted.
Could Be!
Passenger Extra 4081 West at Field.
I have a somewhat different take on this – woman driver jokes aside.
There’s less than 15 seconds from the time the gate finishes dropping to the time the train is on the crossing. That seems short for passenger service where the train is moving as fast as pictured.
She decides to go across, then evidently sees the train coming and stops ASAP; whether she tried to engage reverse ‘in time’ I can’t tell. But this looks suspiciously like a case where someone expected the gates to be down a longer time before the actual train arrived… oops.
Gates are DOWN - wait for the train to pass and for the gates to go UP.
What a original concept!
In any event - once you get on the tracks - KEEP MOVING
She had plenty of warning, and chose to ignore it. That award that shall not be mentioned here comes to mind.
We’re required to start our whistle/horn 20 seconds or a quarter mile from the crossing. Crossing protection is configured to meet that requirement at track speed.
An Experiment in Repowering?
CN 1719, Engine Unknown?
When Built, CN 1719 would have looked like this.
http://www.cnrphotos.com/gallery2/main.php?g2_itemId=51015
Vertical Radiator Shutters, Exhaust Stack at rear of Hood, A1A Trucks.
Engine " Unknown " CNR 1719.
As Built. 539. Stack at Rear of Hood. Vertical Shutters.
Rebuilt, for a time. 1964. A1A.
https://4.bp.blogspot.com/-hqteWuQsaUQ/WY9ZBpQxuDI/AAAAAAAAK9M/jlPeJwulSf08IWwDcpkPvbml24sbuAFpgCLcBGAs/s1600/Sep%2B26%2B1964%252C%2BDelson%2B.png
https://rollymartincountry.blogspot.com/2017/08/the-delaware-and-hudson-in-recent-memory.html
Smaller Rad. Horizontal Shutters. Exhaust Stack and Air Filters at front.
251 Repowering Experiment?
Other Modifications included.
CNR took idlers out of these A1A Units making them B-B and coupled them in sets for Transfer Service.
Seattle Vancouver Trains to Return.
https://www.cbc.ca/news/canada/british-columbia/amtrak-vancouver-seattle-september-1.6508603
Thank You.
Passenger Service Toronto-NYC Returning.
https://toronto.ctvnews.ca/this-train-service-from-toronto-will-bring-you-right-to-nyc-1.5965016
Thank You.
Now we only need the Montrealer, the Winnipeger and the Atlantic to complete the set!
For the Modeller, From ebay. 1967.
Spans the World Crest. CP 4078.
FWIW.
C. April 1967, CP 7116?? and CP 4078?? being handled Dead in Train Six 6 Cars behind Units derailed just East of East Switch Eager on old line Cranbrook Wardner before Libby Dam, and wound up in swamp.
Eager = M. 94.4 OLD Cranbrook Sub to Wardner
Cranbrook = M. 99.2 OLD Cranbrook Sub to Wardner.
CP 4078 needed Nose Repairs and in doing so, CP applied a Spans the World Crest.
https://www.ebay.ca/itm/144649721497?hash=item21adcb9699:g:QqEAAOSwnAZi1IDO
https://i.ebayimg.com/images/g/QqEAAOSwnAZi1IDO/s-l1600.jpg
https://www.ebay.ca/itm/144649720412?hash=item21adcb925c:g:RV8AAOSwqndi1IBJ
https://i.ebayimg.com/images/g/RV8AAOSwqndi1IBJ/s-l1600.jpg
https://i.ebayimg.com/images/g/PmQAAOSw6Iti1IGg/s-l1600.jpg
It did not run long this way and was Out of Service by July 1968.
Another Rare View from ebay.
CP 4100 Montreal West.
Renumbered to CP 1401 1954.
https://i.ebayimg.com/images/g/kaYAAOSwHh5i3Dlv/s-l1600.jpg
https://www.ebay.ca/itm/325280400408?hash=item4bbc390418:g:kaYAAOSwHh5i3Dlv
This would indicate a change from Freight to Passenger Traction
Motor Gearing.
CP 1400/1900 = Psgr Gearing.
For a time Two 2 GP9s CP 8511-12 were Psgr. Geared. S/G
Torpedo Geeps.
CP Ordered new GP9s w Psgr. Gearing, then swapped trucks from under Freight Geared GM S/G Cab Units.
Thank You.
Interior View Montreal Tramways 1250 from ebay.
https://i.ebayimg.com/images/g/2uMAAOSwrBpi3etc/s-l1600.jpg
https://www.ebay.ca/itm/175362362267?hash=item28d4694b9b:g:2uMAAOSwrBpi3etc
Similar Car. There were over 200. Most lasted 40 Years.
http://www.trainweb.org/oldtimetrains/electric/MTC_1398.jpg
Two Man Rear Entrance signified by colour Green.
One Man cars were usually Creme/Red Trim.
http://www.trainweb.org/oldtimetrains/electric/MTC_1687.jpg
The different colours positioned the patrons at the stops to move
to front or rear for boarding when car stopped.
Cartierville 17 was second to last route to get Autobuses,
June 1959.
( We did not know it, but CPR Steam would wind up a year later
Brake Slug on ebay
When extra Locomotive Braking is required when moving heavy
cuts as in Yards, a ‘Dead’ locomotive can be used for it’s
air braking ability alone.
In 1970 CP added a Retired CLC B Unit to each of Two 2
Hump sets, CP 4449 and CP 4458.
Here is the CP 4458 Set on ebay.
https://i.ebayimg.com/images/g/2SQAAOSwDZVi2XYf/s-l1600.jpg
https://www.ebay.ca/itm/155086098226?hash=item241bda0f32:g:2SQAAOSwDZVi2XYf
FYI. The short stack ahead of Bell on CP 8166 is Exhaust Stack
for oil-fired Watchman Heater which keeps Diesel warm when
shut down in Cold Weather.
Thank You.
CN 9344, CP Ogden Shops 1967.
In 1967 CP 4054 hit a Rock on Nelson Sub, demolishing former.
http://cranbrookhistory.com/image_view.php?ID=33225
http://cranbrookhistory.com/image_view.php?ID=33224
CN 9344 was purchased to create Second CP 4054.
https://yourrailwaypictures.com/OldDiesels/21310.jpg
Here are ebay views of CN 9344 in CP Ogden Shops, 1967.
https://www.ebay.ca/itm/379-Original-Slide-Ex-CN-FM-C-Liner-9344-at-Ogden-Shops-Calgary-AB-Circa-1967-/134178528387?_trksid=p2047675.m43663.l10137&nordt=true&rt=nc&orig_cvip=true
https://i.ebayimg.com/images/g/xFYAAOSwqZhi2Wa7/s-l1600.jpg
The rock was the hard place.
Another rare Diesel from ebay.
CPR 8921 RSD17.
https://i.ebayimg.com/images/g/~ogAAOSw4Ppi5E-B/s-l1600.jpg
https://www.ebay.ca/itm/225095636792?hash=item3468bed738:g:~ogAAOSw4Ppi5E-B
Sent to Torrrana to become ‘The Empress of Agincourt’
When Built Demoed on both CNR And PGE.
http://www.trainweb.org/oldtimetrains/CPR_Toronto_Yard/rsd17.htm
http://www.rrpicturearchives.net/showPicture.aspx?id=3188654
Chop Nosed and now Preserved.
Tacked on at end of CPR’s Train Masters CP 8900-8920.
Replaced @ Hochelaga by CP 8901 and CP 8407.
http://www.trainweb.org/oldtimetrains/photos/cpr_diesel/8901_.jpg
That would be Rock with a capital R…
CN still does this, the SD40s and other six axle units that have been ‘demoted’ to yard and hump service are not set up to supply power to slugs, but at Mac and Symington they are commonly paired with slugs.
https://www.traingeek.ca/wp/a-visit-to-the-hump/
