can windex be used to strip paint off a model?rambo1…
No.
Mark.
Rambo,
So we can help you, provide some details. What item are you planning to strip the paint off of?
If you’re stripping a P2K, Walthers, Atlas, AHM, Bachmann, HO equipment you will likely be successful using 91% isopropyl alcohol, Chameleon Strip Clean (if you can find it) , or ELO.
On my last strip job I used straight 91% alcohol. It worked as well as some paint stripper I had on hand. The reason I tried alcohol is because I use alcohol on a pad to clean the track, and when I picked up a car there was alcohol on my hand which took the paint off the car.
Soak the car in the alcohol for a while and brush the paint off.
Good luck.
Lee
