Not actually a first time poster, although it might show up that way; I goofed during my renewal this year by using my work, and it effectively created a new account for me.
Anyhow, due to space constraints, my two end-of-life staging yards share a peninsula, with one side’s yard feeding the northbound main going clockwise around the walls, and the other side’s yard feeding the southbound main going counterclockwise around the walls. All track is N scale Peco 55 with electrofrog turnouts powered by Frog Juicers.
I decided that it’d be pretty convenient to have a crossover between the yards near the end of two stub. However, the polarity of the rails are opposite, so a reversing section is needed.
Where’s the best place to put the actually reversing section in such a scenario? My first thought is it needs to include one of the switches and the end of that switch’s stub track. But would this cause any issues with using a Frog Juicer for that switch’s frog? It would mean a double juicer for the reversing section plus a single for the frog, and the single would need to flip fast enough after the double juicer flips the stock rail polarity to not cause a noticeable pause in operation. I can push the insulators between the divergent routes as far away from the reversing section turnout as possible, about 3 inches. But I don’t know if that would matter so much, since if there’s decent electrical contact between the stock rails and the point rails, then as soon as the stock rail polarity gets flipped so would the frog.
If the above is viable, has anyone had any issues with the single frog juicer? I’m not sure how they would respond to the input polarity on the board itself changing.
I don’t know if the photo will show here, so there’s a link to the same pic I uploaded to Google drive. Obviously it’s a simplified diagram, but it shows the proposed crossover connecting the two yards, and following the main around you’ll see that the A and B rails would be mismatched at the crossover.
Thank you!! Working from my phone was a pain; took forever just to figure out how to reduce it to a resolution that might display here simply for everyone. Cheers!
Ok, to expand on what the simplistic diagram shows, I have a balloon track connecting the left and right yards to enable continuous running but which won’t be used during op sessions as the yards are 30 miles apart, operationally. Likewise, the crossover will only be used between sessions to quickly reverse engine directions without resorting to the 0-5-0 switcher. The shortest stub below the crossover is just long enough for a double engine lash-up to transfer to the opposing yard.
Had some time to think this over, and I think I see two solutions.
Since the peco electrofrog require insulators on the frog rails, the turnouts are electrically already isolated. If I put insulators on the north end of the left-side turnout, that turnout and its tail stub would be the reversing section.
Pros: During operations (ie: when the crossover wouldn’t be utilized), I can park trains on the straight paths through both turnouts, treating both as if the crossover didn’t exist. Possible con: I’m not sure exactly what I attach as inputs for a separate frog juicer to power the frog of the turnout within the reversing section.
Treat the entire crossover and both tail end stubs as parallel wreckage, and put in a short, 2-engine long reversing section north of the left-side turnout.
Pros: Avoids possible frog juicer issue. Con: During ops I could only park a train as far south as the north end of the left-side turnout.
Are there other options I’m missing?
I’m leaning option one, but would like input from folks who’ve powered their frogs. Anyone with a wye in a reversing section which also has a a frog juicer to power the frog? I can always leave out that juicer and just keep the point rails clean for electrical power to the frog easily enough.
i believe the lower right turnout of the cross over needs to be completely isolated to make it a reversing section. That means all 4 diverging rails need to be isolated
the frog juser should be connected to the rails w/in the reversing section
SPOTSfan: No, the feeds are reversed from “normal” for the far yard, regardless which side you are standing in front of. I wired the layout with “black to back” all the way around the room, and that follows into the peninsula too, such that the back rail of the yard you are standing in (either one) is black, and the nearest rail of the other yard is also black.
Gregc: Correct, all the divergent rails of the right turnout would need insulators for it to be used as a reversing section. I reversed my lefts and rights in my last post … I forgot which way I drew the crossover.
With the frog juicer, just splice into the rail feeds for the reversing section then? Instead of straight from the buss, like would normally happen?
