Has anyone have any experience building “STUB switches”?
I am about to attempt to build one.
I am thinking it will be easier that shaving a rail point and the groove rail to except the point.
I am also thinking it will be easier to isolate electrically.
I am going to use a modified Aristo rail joiner. I will cut out a section of the joiner to catch and hold the moving rails. I need to make a crossover from inside track to outside track. The distance between inside to outside inner rails is 4 inches.
I am using Aristo 20 ft dia curve track. I need the 20 ft to accommodate my articulated engines. I attempted to match Aristo 10 ft dia. The engines kept derailing and shorting (electrically).
I have not made stub swithces before but have made a standard point switch. I am a member of the WW&F railway museum which has a three way stub switch leading to their yard and engine house. It is pretty neat.
It certainly is simpler than milling down the rails especially if full scale. In our scale a good sharp (new) course file will make fairly quick work of tapering the points if you clamp them in a vise and go at it with an atheletic mind set.
Remember that the real railroads changed to point switches for a reason. your engines will end up on the ties if the the switch is not aligned correctly and of course if it is set for the wrong track.
I hand laid all my track inside the garage and used LGB R3 outside. I started building stub switches and built a pair as a crossover. I tried to power them using Tortoise switch motors, but I found them too heavy, even after I fine tuned them time and time again. I gave up and built the other ten switches as regular switches, with point blades. These are all powered and work fine. I eventually used manual mechanisms to operate my stub switches. I also find that they cause derailments, as Cap’n Perry says, whereas the point blades allow the the wheels to slip through, or hop over.
You may have more luck, or be a better builder. Good luck and let us know how you get on. Oh, and send pictures.
If you do make a stub switch, can you make a thread on how to build it, since your other how to threads are quite informative and as you said before; it may be easier to make than a switch with a point. Thank you. - Peter
Do a Google search for ‘The Civil Engineers Pocket Book’. It is a downloadable PDF and has some great railroading information in it. I believe (without searching) it contains some information on stub switches.
I had one photo of the stub switch which shows the cross overs but not the stubbs. I do not seem to have any photos of the stubb end at this point…I’ll look through my archives.
The WW&F uses this switch only for slow speed operations. it is not on the main line.
here is a photo of the switch looking from the other direction (cropped from a larger view)
All six stubs are are spiked firmly in place. these are where the “points” usually are on a standard switch.
the two moving stubs are controlled using the switch stand on the left which has three positions. the handle folds down into a rack with notches to hold it securely in each position. you can see a little bend in these rails as they blend from the mainline switch by the passenger car to thye right most track behind the caboose.
this switch was made by volunteers at the WW&F railway museum http;//www.wwfry.org I helped make a standard switch on the main line this fall…even for a two foot gauge track and with all the parts at hand it is heavy work!
I love the three way stub switch, and let’s face it… two foot gauge steamers are just too neat! One of these days I have to make a pilgrimage up to the WW&F.
But back to the subject at hand… I have never built a stub switch in “G” scale, but I originally built my 12" gauge railroad with stubs for the same reason that was mentioned - I didn’t have to cut, grind or fabricate special points. However, I have now converted all of the original stub switches to point switches. There are several reasons that I did this, none of which might apply to the OP’s situation.
First, by using springs on a regular point type switch, there isn’t any damage or derailment if I accidentally run through a switch set against me. In fact, I have certain switches with carefully adjusted the springs and properly reinforced points that are designated as spring switches. Run through a stub that is set against you and the flanges will be cutting grooves in the ties. Not a big deal on a garden railroad, but a very big deal with a 1500 lb steamer.
Second, the stub switches are more prone to problems with rail expansion. The first switches I built would bind up as the points expanded into the other rails on hot days. I was able to solve this by building a frame out of 2x4’s and screwing all of the switch ties to it - the frame is hidden under the ballast. I then securely fastened the rails to the ties on both sides of the points and used very generous expansion joints on all rails either side of the switch. All the joints on my railroad allow for expansion, but the rails can still creep from summer to winter to summer. The point type switches don’t have these problems since the points can’t bind on the ends and the stock rails are continuous through the switch.
Finally, the stubs seem to have a lot more problems in the winter with snow and ice buildup. I guess it’s because
