I have a pair of old Atlas/Rivarossi N scale C-Liner shells from the 60s that I need to strip some paint off of. The paint is on there pretty thick from custom paint jobs from whoever had these shells before me; it hides some of the vent detailing and is very uneven.
I have put the two shells through many an alcohol bath with 91% rubbing alcohol, then going after the paint with a firm bristled tooth brush, and have made some progress, but not as much as desired. The paint is very stubborn…
What can I use that won’t attack the 40 year old plastic to get the paint off of there? And I’d rather not use brake fluid.
WD-40 has also worked for me with those stubborn paint jobs so you might give that a try if you have some on hand. Never had a problem with it attacking plastic.
I have never had much luck getting the paint off of those older Atlas shells unless I grit blast them. I have triesd all sorts of chemical strippers (alcohol, castrol, Chamelion). some work fairly well, others wont touch it. By the way, brake fluid is basicaly an alcohol which is why it removes some paints unless you get one of the newer silicone based fluids.
