I’m having a problem with my airbrush that I’m wondering if anyone has come up with a solution.
I have a badger 175 dual action brush that has a rubber finger pad on the air button. That little rubber pad doesn’t stay on the button. It keeps coming off at the most inopportune times. The little rubber pad makes a big difference in the precise control of the paint flow.
CA is too brittle and won’t hold the dissimilar materials once the rubber starts to flex. Use contact cement, Goo or better yet, a rubber cement, Pliobond. The replacement rubber tips on a couple of my finish nailers always keep coming loose and popping off. I found that Pliobond has held them on the best. These things see cosiderable use on a daily basis.
