Stupid question: Digitrax Throttle DT402
The display shows the throttle as a percentage (Between 0->100% throttle) (According to the manual)
Is there a way to display the current speed step?
There’s a calibration routine I want to try, and the instructions tell me to set the engine at specific speed steps for each calibration.
Other than carefully count the clicks, no. 128SS is actually 126, so calculate the current speed step using a percentage of 126.
JMRI can show the exact speed step for a given loco by looking at the slot status in the command station. Or the on-screen JMRI throttle run in speed steps as well.
Like Randy mentioned, the Decoder Pro(JMRI) software will show the actual speed step. I guess my question is ‘why’ are you concerned about the actual speed step? In actual practice, a decoder has only two modes: 14 speed steps, and 28 speed steps. It calculates the128 step via an internal algorithm.
If you are speed matching two engines, what really matters is do the run at the same speed at the same throttle setting. Even two identical models may have differences dues to friction in the drives and the same exact settings will not produce the same result.
Jim
Well to set up BEMF
QSI recommends starting at speed step 8
Soundtraxx, says speed step 20
I know the conversion is simple. But it’s not 1:1 as there is more then 100 speed steps. So I guess it’s either time to use the QSI programmer as command station mode, or use JMRI.
Thanks for letting me know guys. I was hoping there would be a work around. I guess not. Maybe a future firmware update will solve the problem. (Make it a cab option)
If you have the throttle set up to beep as speed is changed you will notice that every third beep there will be one extra beep before the display increases. This is how Digitrax gets the 128 speed steps on a 2 digit display.
One of the people on the Yahoo Digitrax group matches speed using a measured test loop of track and a stop watch. He has a table of scale speeds based on distance/time on the measured loop. Scale speeds are set to match the throttle display for every engine. This way every engine is running the same speed at each number on the throttle. He’s N scale, but the same could be done in other scales with a little calculation.
here’s a link to his speed matching web page: http://www.cuttergraphics.com/N-trak/speed_matching.htm
Martin Myers
Hmm, I guess I’m not so picky, but my locos all run well and creep nice and slow, and all I do is set them up to run as slow as they can on speed step 1 or 2. My motor only deocders are all TCS though, there aren’t any BEMF settings, they self adjust, very well I might add. My one Tsunami runs great out of the box, as does my one QSI.
What’s more interesting is that a mix of locos runs well together without doing and speed adjustment - The Tsunami with a TCS, and also a pair of Proto Geeps with TCS cooupled tot he Atlas Trainmaster with a QSI - they all run great together and I’ve changed nothing. If I set them on the layout a few feet apart, they don;t run perfectly in step, but coupled together with a train they don’t jerk and buck at all.
