I’m considering building a trestle out of styrene. But I really don’t have a clue about what dimensions of styrene and what brand I should get. I’m thinking of doing two of them. One large and one small. The large one will probably be between 30 and 50 cm and the small one 15-25 cm.
Any sugestions would be very helpful since I’ve never used styrene to scratch-build something before and I do not have any possibility to got to a LHS and check different sizes.
But I got those videos. They only show a small trestle and I’m looking for something bigger. I’m not sure that those “timbers” would be enough or a larger one?
I was thinking since you mentioned you were going to make a small one, cut your teeth on one like Joe’s. Then when you have better understanding of them and how they go together, you could use the references he quotes to get the specifics for a larger one. He also talks about making his larger one too. Worth watching the chapter again I would think
How much bigger? Will this be for a main, branch or logging line? I agree with ratled about making a smaller one first. It would give you a good idea on what and when to do things such as when to rough up the timbers to give them simulated wood grain etc. You might want to get one or both Kalmbalch’s books on bridges and trestles http://kalmbachcatalog.stores.yahoo.net/12101.htmlhttp://kalmbachcatalog.stores.yahoo.net/12452.html
I have the first one but not the second one yet and find it very handy. I also have #00099 Bridge & Trestle Handbook from Carstens and it too is very helpful. http://www.rrmodelcraftsman.com/depot.html
They will give you information on when square timbers vs. round pole pilings are used.
Hey, Harold, you’re getting through to some of us. [swg] I’ve cut up most of the odd pieces of stripwood in my stock and have placed it, mostly in gondolas, as used dunnage and blocking.
With a bit of other junk and dirt, it doesn’t look too bad, but I no longer use wood for scratchbuilding, thanks to your suggestions.
