Styrofoam - Any Negatives?
All,
I searched for a thread on this subject but couldn’t find one right off, so . . .
For the last seven or eight years I’ve collected a tidy amount of styrofoam used as packing for furniture kits and other items. Thought that it might make an appropriate foundation material for hills, other scenic items and who knows what else. Most is in sheets of varying thickness but I also have some modestly sized blocks. Most of the stuff has a relatively fine “grain” and is a bit more dense. Some is a bit more coarse and can create a small snow storm if handled roughly. I’m imagining that Gorilla glue or another common adhesive will do to aggregate it according to need and design. I’d like to make use of it as disposal will be a pain in the neck - or elsewhere.
I expect that there will be some amount of “fluff” producted in the cutting and sculpting of it. Not sure I want to pony up for some hot wire cutting gizmo that might be out there. I’ll just have to keep a small vacuum handy as I have at it with blades or whatever.
Except for the down side of the chaff produced, are there any other liabilities for this use of styrofoam? And while we’re at it, once it’s been contoured, what materials and techniques are best for surfacing it in preparation for grass or other applications?
I will not be using it for rocky outcroppings, cliff faces or anything else that will require finer surface detail.
I know that there’s a lot of current chatter on the forums about pink foam. But i’d like to get rid of this stuff first. And so would my Sweetie!
Obliged, as always.
John
I have used some styrofoam, the white beadboard kind that is pretty messy to cut but can be shaped neatly using a hot knife or hot wire tool – in a WELL VENTILATED space, preferably outdoors. The smell is considerable and unpleasant, so warn others in the house beforehand. Do take precautions.
It doesn’t take long to learn how to make the shapes and contours you want, and I am very happy to use it. I model the midwest with mostly gentle rolling hills not mountains.
What I like is that you can experiment with little risk. Does the hill look too high? Use the hot wire tool to lop off the top. Change your mind? Glue that piece back on.
Woodland Scenics offers their own line of the stuff, in a large selection of thicknesses, rather more dense and less “beedy” than the usual packing material you can get “for free.”
Woodland Scenics’s Foam Tack Glue works well on all kinds of styrofoam in my experience.
Dave Nelson
  1. I use knives and saws to cut foam shapes. Keep your shop vac handy, and perhaps wear a dust mask if you’re gonna get crazy.
  2. I used gorilla glue at work for a foam project. It’s very strong, and is also gap filling. The molds I made had gaps between the layers, and the glue flilled them well.
  3. As for surfacing, you can simply paint it with latex paint if you’re going to use ground foam. Or you can add a thin layer of paper mache or plaster cloth.
  4. I’d suggest using the pink board for the subroadbed, then the white beaded chunks for hills, etc…
I built my mountains with the type that creates snow storms and have been happy with the results. It is messy but super strong. As with most Styrofoam you have to use the proper glue or it will melt.
I covered the carved Styrofoam with Paper Mache and wouldn’t recommend it because it shrinks as it dries. I learned through the process by covering the Styrofoam with plastic wrap first prevents the shrinkage from screwing up the Styrofoam. After the Paper Mache has fully dried remove the plastic wrap and glue it in place, that works very good.
The guys on the Forum put me onto Sculptamold and it works very great, much better than Plaster of Paris or Hydrocal for ground cover. For rocks I use Woodland Scenics rock molds with either Plaster of Paris or Hydrocal cemented to the Styrofoam with the same. I bought a cake decorating applicator for applying plaster or Hydrocal as the glue to hold the rocks and fill in any gaps between the rocks. Don’t let the plaster set up in the cake goodie or it’s a goner. I keep a bucket handy to dunk it in before the stuff sets up.
Thanks, Dave, Bundy and Mel. This is a good start.
John
Foam is all I use for table top and landscape,all mine was reclaimed from the dumpster. I stay away from the beaded stuff because of the excess mess, and the fact I have so mutch of the pink and blue.
I glue mine together with plain cheap caulk. To cut; score with a knife and snap. Any kind of sawing is more mess to clean up. I cover mine with drywall mud,in case of a joint, use drywall tape over seam.Smear the mud on,work it with a water wet brush. You can carve the mud or foam with any thing sharp and pointy.Myself I wouldn’t spend money on any kind of ‘‘hot knife’’. You’ll use it a few time and then it sits.
I just tore down my layout and the tape/mud joints were stronger then the foam.Had planned to reuse what I could but found a pile of nice clean stuff.
The only neg I found was mounting the ground throws for turnouts, Now that I got that figured out, no problems at all.
Gorilla Glue makes a fantastic bond between foam sheets, but keep these in mind:
  1. Gorilla Glue expands when it dries. The foam must be clamped together or it will be pshed apart.
  1. Hot wire cutting tools do not like contacting Gorilla Glue.
-Kevin
I use the pink stuff, the blue stuff, and the white pebbly stuff. Everyone is right, the white pebbly stuff scatters into a million pieces. You need your Shop-Vac standing by. The other thing is that all three generate static electricity, and that makes it difficult to throw them away. Those little bits and pieces and thin slices are so light and so clingy that you’ll end up looking like a Buster Keaton movie.
I have some old pink stuff and some new pink stuff. The old pink is a little more crumbly and the new pink is a little denser and more uniform in texture and it carves like deli meat. I use a razor sharp 7-inch fillet knife and a 3-inch X-acto flat blade, also razor sharp. I’ve used the hot wire before, but that is a little difficult to control. I don’t own one (I borrowed one), and I suppose with practice you can get pretty good at controlling it. After the big pieces are glued into place, then you can shape it with a rasp or coarse file or chisels or serrated knife or rough sandpaper (I have some 20 grit) or whatever.
For glue I use acrylic ceramic tile mastic. It is a little thinner and a little fluffier than caulk. A one-gallon bucket cost about $12 at the big box stores, and it contains about as much as 20 or 30 tubes of caulk. Spread it on evenly like peanut butter with a putty knife or use a notched trowel. You don’t need very much. It holds in place instantly and takes a couple of hours to firm up. It makes a very good bond. I’ve used white glue and yellow glue, but the structure of the rigid styrofoam is made up of closed cells that keeps air out, and it takes literally a week for those glues to dry.
Robert
Good stuff, Robert. Maybe I should price out some of the pink and blue stuff, especially if it’s easier to work and won’t create a blizzard.
BTW, earlier today I saw your string of posts that displayed the benchwork progression of your move into your attached garage. Really nice craftsmanship. Did you ever manage to get your car into the detached garage that you built? [;)]
John
Ventilate, ventilate, ventilate. The fumes from beadboard are way worse than the pink or blue styrene.
I’ve used the white styrofoam underneath the pink or blue foam to build up mountains. I shy away from using it as a top layer due to the much mentioned and experiences snowstorm effect.
Umm . . . no. [:$] Still parking in the driveway. I guess that’s what you might call ironic.
Robert
Robert -
Yes!! On some metaphysical level, justice prevails. The weekend is better already.
John
Ain’t it the truth! Speaking of which . . . that sound you won’t hear will be me chuckling when you’re sitting there wondering how those millions of tiny styrofoam flakes managed to infect your socks and underwear drawer. [(-D]
I’m not sure why anyone would still be chipping and cutting away at Styrofoam, either as underlayment or surface forming, when even commercial hot-wire tools are under $20 and it’s reasonably easy to 'gin your own up with appropriate Nichrome. MUCH cheaper than, for example, a Shop-Vac setup at your elbow and all those bags you’ll need to contain the flinders…
If you must use the Shop-Vac approach I’d recommend using one of the Surform style ‘multiplanes’ for shaping, instead of hacking away with tools that have raked teeth. Your socks and, ultimately, various tender parts of your body will thank you in the long run…
Robert and Overmod,
Well, that does it. Styro-flakes threatening my socks, underwear drawer and tender parts tipped the scales. Guess I’ll have to chuck the furniture packing. Don’t want to have to 'splain away the unforeseen consequences of using it to the little lady. [:$]
John
I think the advent of using styrofoam (not the white beaded packing stuff, mind you, but the flat insulation sheets) for model railroading was a huge step. Relatively cheap, wide variety of uses, fairly easy to work with, goes a long way, and very forgiving. I mostly find the pink stuff at my HD.
Downsides: 1) be careful you don’t use any solvent based paints or adhesives, which corrode it badly. 2) creates lots of very messy chips and flakes when using rasps or knife-edges to create irregular forms, and the chips are static lovers. You absolutely need a good shop-vac handy!
I’m sure that coming from Portland, you shouldn’t have any problems finding the extruded foam (blue and pink board).
I’ve learned from these forums, that our friends in the warm states, don’t have access to it. Which baffels me, as it’s used in many construction applications. The backing for exterior stucco and plaster finishes, and under cold storage building floors.
I used the extruded, and stayed away from the expanded bead board.
Mike.
We’ve used Styrofoam on our layout in conjunction with blue-board, all leftovers from shipping and construction. Styrofoam has been fine for everything that was NOT AN OUTER surface.
  • Lower levels to build layers of styro under hills and high points
  • invisible tunnel interiors
  • under structures where buildings & sidewalks cover
Outer layers that were scenicked then sit atop the styro base. All laryers bonded with construction adhesive in caulk gun for large areas or Liquid Nails from tube on detail areas. After 5 years, no problem.
Sounds like you are planning to go this way & should be fine.
I have been frequenting Home Depot a lot more with all the work I am doing on the kitchen.
Much to my surprise, when I was in there last week, there were 4 by 8 sheets of pink foam in 5/8", 1", and something about 2" thick. First time I ever saw it there.
All measurements are approximations.
-Kevin
