Firefox, Java and MRR Do not mix very well…check that You’re Java is up to date. Even then it is hit or miss. Had the same problem couple yrs. ago on all CS.Trains sites with Firefox, but on other sites it would work fine…except for the freezing…got rid of it… Chrome plays very well with all CS. Train sites…always.
Yes I have used Firefox on a lot of sites also and everything worked fine for awhile, then things started going crazy…could not get the quote to work no matter what I did. Then some other functions did the same thing…then it would freeze up, on not only this site.
I have no problem with Chrome on any site and the spyware is not an issue for Me. My anti-virus/spyware takes care of that…but I do pay for it every year, It makes Me invisible when I am on the internet.
After many failed attempts to get the system to recognize me, I was able to confirm that unless I selected “Keep me logged in”, the system recognized my account log in information, but didn’t recognize me as a subscriber.
I find it amazing that they would fall back on the old “must be your browser” story when, not that long ago, they posted an item in the forums stating they knew they had problems.
I still can’t get the system to recognize me as a subscriber unless I use the “Keep me logged in” box.
I shouldn’t have to do that. The reason it’s a box that can be checked or unchecked is that it’s a choice you should be able to make.
You shouldn’t have to select it to get their system to do what it should.
And, just for the record, I’m using the latest version of Firefox. It’s set to clear cache on closing. I also run CCleaner to clear cache and logging out and back in again does nothing.
I use Fire Fox, and the quote feature doesn’t work, and the drop-down menues/boxes don’t work either. They do in IE. As far as logging in, no problem until early this am. Called customer support, and they couldn’t log in either, and told me they were contacting the tech. dept., and to try later, and said “something is going on here that is not on your end”. Now, this pm, when I logged in, it worked.
Fire Fox is to date, Java is to date, and my system is Windows 7, Professional, with IE 8.
