Greetings!
Background:
I’m a member of a modular layout group in the Puget Sound area of Washington. We don’t have a permanent location, but set up 4-6 times per year at various shows and/or special events. Thus, our needs tend towards 1) portable, 2) sturdy, 3) easy to set up, and 4) reliable.
Project:
In conjunction with the turntable I’ve been scratchbuilding, I’m working on improving the control panel setup for my three modules. There will actually be two control panels:
- Main control panel for operators, to be located inside the loop of modules. About 12"x18".
- Very simple small auxiliary control panel on the outside. About 8"x8". This will have two very prominent LEDs, and two pushbutton switches: LEDs labelled “Sorry, the turntable is in use by a club operator”, and “Go ahead and run the turntable”, switches for “Clockwise” and “Counter-clockwise.” Hoping to give the kiddies a little thrill by letting them actually interact with the module, so long as the turntable is not actively in use.*
As you can guess, both of these will need to be sturdy. In particular, I want to make sure that the “public” control panel will not fall off the front of the layout under the “influence” of little hands.
Query:
So, I’m looking for suggestions as to how to attach these control panels. I spent a period of time in the hinge and cabinet hardware aisle of a big-box store this morning, and have a couple of ideas based on barrel locks, but am wondering what else is out there?
I had toyed with the idea of hinges, with the pin being removable for transport, but I didn’t see many (if any) hinges at the store where the pins weren’t captive (non-removable).
It would be particularly nice if the inside control panel were able to fold down when not in use (clearing more space in the a
