Jim,
Sulzer engines have been used in locomotives all over the world in quite large numbers, including the first fast passenger diesel locomotive in France in 1938, contemporary with the early E units. A number are still used in Eastern Europe and in China, and until recently they were used in England.
This was the 12 LDA28 model which developed about 2500 HP and consisted of two six cylinder engines built together, side by side as a single unit, and geared together to drive a single generator. As you can imagine, this was an expensive engine to build and maintain. A later vee type engine, the LVA24, was built in the 1960s but wasn’t a success.
Sulzer tried again in 1978 through Morrison Knudsen, who rebuilt four SP U25s with an eight cylinder, in line engine model 8ASL25/30 of 2800 HP. The numbers in Sulzer engine models refer to the bore, or bore and stroke in centimetres. These engines are generally similar in bore and stroke to the new GE and EMD four stroke engines.
MK also rebuilt four SD45s for Santa Fe and another four for UP from 1980 to 1982, using the bigger 16ASV 25/30 3600 HP engine. UP scrapped their units but Santa Fe converted theirs back to standard SD45s with EMD 20-645E3 engines in 1985.
MK also converted one GP9 with a 6ASL engine, but did not sell it.
Caterpillar tried similar conversions with no greater success, so it wasn’t just a problem with imported engines. The poor acceptance of new engines from both GE and EMD in their 6000HP locomotives probably indicates that the present EMD and GE engines have been developed to take account of specific US operating conditions, and are a hard act to follow.
Some European engines still attach their access covers with fifteen studs, nuts and washers around the edge, rather than a single spring loaded handle in the centre. There are probably many other features that would cause problems in running maintenance on a day to day basis, and result in longer down time.
