S. T. P. PART 3
57 WORDS
- Ives’ first (_ - _ _ _ _ ) locomotives appeared in the 1912 catalog. With bodies and truck ( _ _ _ _ ) made of ( _ _ _ - _ _ _ ), the No. 3240 0 - B - B - 0 rode on ( _ _ _ _ - _ _ _) rails as did the slightly more economical No. 3239 version released the following year.
- Besides the distinctive cast - in (_ _ _ _ ) heads, the No. 3240 locos featured dual operating ( _ _ _ _ _ _ _ _ ), separately applied ( _ _ _ _ _ _ _ ) and tiny ( _ _ _ _ ) between the end railings and between the ( _ _ _ _ ). The No. 3240 was modified in 1921 to run on ( _ _ - _ _ _ - _ _ _ - _ _ _ _ _ _ _) inch gauge track (aka Lionel Standard Gauge) to use up existing stock while Ives switched over.
- At the same time, Ives’ (_ _ _ _ ) began using ( _ _ _ ) metal for locomotive bodies. For budget - conscious consumers, Ives offered the 0 - B - 0 Nos. 3241 & 3242 ( _ _ _ _ ) cab locos. The difference between the two related mostly to ( _ _ ) features. However, both could come equipped with simulated ( _ _ _ _ _ ) third - rail pick - up ( _ _ _ _).
- Besides changing the (_ _ _ _ ) of their large trains, Ives also replaced rubber - ( _ _ _ _ _ ) lettering with brass ( _ _ _ _ ) starting in 1925. Two large ( _ _ ) - shaped plates flanked the door on each side of the ( _ ). The one on the ( _ _ ) typically read “The Ives ( _ _ _ _ _ ) Lines” while the other featured the ( _ _) logo.
- Collectors will search far and wide for a No. 3241 or 3242 from 1924 wearing (_ _ _ ) - colored paint and lettered for a ( _ _ _ _ _ _ _ _ _ _ _) based depart
