Do Sunrise Enterprises FREDs flash on and off like the real ones or are they constantly lit where you have to buy a flasher module to make them flash? Also, while I’m on the subject, where can I get axle wipers to power the FREDs off the rail? Any other info you have on FREDs/EOTs is appreciated. I am needing this for HO and N scales by the way. Thanks.
I can’t help you with the sunrise enterprises EOT’s, but you mentioned wanting other sources. Here is a fairly in expensive version, the one that I am planning on using:
http://www.greensteamproducts.com/EOT.html
Noah
