Hey Its me Jayman agian just wondering can i join up 3 seperate tracks and only use one power controler. ie Using a terminal to seperate power supply to different tracks but only using one train controler to work the train.
Is It possible??
Is It possible??
If I understand you correctly, wouldn’t an Atlas Selector switch do a good job of that?
Terminal strips or other power bus can be used to provide power to as many points on the track as you desire–opinions vary, but many suggest that power feeders should be placed every three feet or so along your mainline–some say every piece of track should be individually powered!
Might be a good ides to use seperate switches for those tracks so you can turn them off if nessecary, for parking a loco for instance. I’m assuming your using a DC controller.
Ken.
